Sponsored by: Wheel Design
2022 visualizer is up!
Old Jul 25, 2021 | 03:38 PM
  #121
skrupski's Avatar
skrupski
That is what I have been using, 2lt coupe. Dealer also assures me it will be body color or carbon flash if ordered that way. I wish there was someone/someplace to get clarification but a while ago I asked and got nothing back. I tried a bunch of colors and it always came up body colored.
Old Jul 25, 2021 | 04:20 PM
  #122
skrupski's Avatar
skrupski
Sorry, you guys are correct. Some how mine got changed to a 3LT. And I did not do it. Now I am concerned.
Old Jul 25, 2021 | 04:24 PM
  #123
raycer's Avatar
raycer
It defaults to 3LT. Select rapid blue in 2lt and it will be body color. Weird .
Old Jul 25, 2021 | 08:06 PM
  #124
Zymurgy's Avatar
Zymurgy
Moderator
The color of the low wing spoiler is causing considerable discussion. As I stated before, I think the visualizer is wrong:
Originally Posted by Zymurgy
I'm convinced the visualizer has this wrong. For example, try Rapid Blue 2LT - it shows the low wing in body color. I really think the low spoiler will come body color, just like the standard Z51 spoiler does.
I'm trying to get confirmation from the Corvette Team with regards to the low wing spoiler color on all trim levels.
Old Jul 25, 2021 | 08:14 PM
  #125
skrupski's Avatar
skrupski
Appreciate the help. Was going to try and call Chevy but did not have much hope.
Old Jul 25, 2021 | 08:44 PM
  #126
Mikeki7's Avatar
Mikeki7
Would also be nice to know if the low spoiler mounts the same way as z51 spoiler or tape only. The part numbers need to come out asap so I can place one on order!
Old Jul 26, 2021 | 11:30 PM
  #127
Zymurgy's Avatar
Zymurgy
Moderator
Confirmed. The default color of the low spoiler will be body color regardless of trim level unless you also order ZYC which will give you Carbon Flash Metallic side mirrors AND low spoiler. There is no such thing as a flat black low spoiler. The visualizer is wrong.
Old Jul 27, 2021 | 12:15 AM
  #128
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
It works .................. sorta. Click the "New low rear spoiler" picture and the spoiler is body colored. When one clicks that and then the picture labeled Carbon flash-painted outside mirrors and spoiler, the low spoiler will change to black. Go figure
Old Jul 27, 2021 | 12:40 AM
  #129
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Didn't work for me - still shows black low spoiler.
Old Jul 27, 2021 | 12:47 AM
  #130
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
I had to click the low spoiler picture first. Leave it check marked. Then check marked the other picture for cf painted outside mirrors and spoiler. Check marking the picture of the new low spoiler only will leave it body colored.
