Sponsored by: Wheel Design
Engine temp in traffic
Old Jun 16, 2021 | 11:17 PM
Binko247's Avatar
Binko247
Default Engine temp in traffic
I drove my C8 for the first time in slow crawling traffic today. Normally the water temp is between 180 and 185 deg. Today in the traffic, I saw it climb up to 205 before the traffic started flowing.
I don't know how much higher it would have gone if the traffic stayed at a crawl. The outside air temp was only in the low 80s. Does anyone have any experience with how well the C8 handles tough traffic conditions in the summer?
Old Jun 16, 2021 | 11:31 PM
Grey's Avatar
Grey
Non Z51 or Z51, AC on or off?
shiumai's Avatar
shiumai
Modified C8 of the Year 2021 Winner
Z51 or non-Z51? Based on my experience at Spring Mountain/Ron Fellows this past weekend in 105°F heat, where we had the AC on the whole time and were either idling for extended periods, pushing the cars pretty hard, or just driving around, the Z51 C8's they had handled the heat really well. Coolant temps were hovering around 200, plus or minus about 10 depending on what we were doing. 205 coolant temp is within normal parameters.
Spamburger_Hamburger's Avatar
It's 100% totally fine. Look at the gauge next to the temp. You can see how close it is to being too hot, and 205 is pretty cool for chilling in traffic. Mine has hit 215 a few time on hot days which is still totally fine.195 - 220 is considered normal per GM.
Old Jun 17, 2021 | 07:44 AM
MagicGlass's Avatar
MagicGlass
If it exceeds 220 then you worry otherwise your fine.
Old Jun 17, 2021 | 09:10 AM
Binko247's Avatar
Binko247
Thank you for your responses. Yes, I did have the A/C on in my non-Z51 car. I agree that the needle was still near the center of the gauge, I just found it a little concerning that it moved up 20 deg from where it normally is.
Your input has relieved some of my anxiety.
Old Jun 17, 2021 | 03:32 PM
Red Mist Rulz's Avatar
Red Mist Rulz
The radiator fans are programmed , IIRC, to come on around 215F, I think. So 205 is well within what GM says is acceptable.
Old Jun 17, 2021 | 03:53 PM
rponfick's Avatar
rponfick
I have never had my fans come on, and I have not seen anything over 215.
Old Jun 18, 2021 | 02:40 AM
bluan's Avatar
bluan
I noticed the exact same thing as the OP, and I was not even using AC. I think this is independent of whether the car is Z51 or not, although mine is Z51 HTC. I also noticed that as soon the car starts moving at the normal driving speed, the temp gangue immediately dropped off from around 215 to 195. So I'd agree with others above that this is normal, although, I have not sitting in traffic jam and not moving for an extended period of time, so I was similarly curious as the OP when I saw this phenomenon.
Wonder if anyone else has ever had your car in traffic jam for a long time (say, more than 10 or 15 min) with the engine running and the car not moving or barely moving, and what did you see on the temp gauge.
Old Jun 18, 2021 | 06:53 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The C8 runs cooler, even in traffic, than the C5, C6 or C7. I would routinely see 225 in those cars while in traffic on a warm day. I got caught in traffic yesterday (83 degrees) and it only got to about 207. Not a problem at all. They are designed this way.
Old Jun 18, 2021 | 11:08 AM
5632's Avatar
5632
Yesterday while driving I was watching closely the temperature. The outside air temp was 115. My C8 water temp was 173 while moving 40 to 45 MPH. At a stop light it might go up to 183.
I have inquired on another site and ask what .temp thermostat is used in a C8 and cannot get an answer.
Old Jun 18, 2021 | 11:11 AM
acroy's Avatar
acroy
That is nice & cool. Don't worry
Old Jun 26, 2021 | 05:41 AM
C821's Avatar
C821
I get around 207-210 in traffic in LA area. The fans come on when I park in my garage sometimes.
Old Jun 29, 2021 | 07:13 PM
5632's Avatar
5632
I am starting to think the the non Z51 C8,s run hotter because they do not have the third radiator. I still have never seen my temp. get to 190 even in days over 110 outside with the Z51 package.
Old Jun 29, 2021 | 08:17 PM
C821's Avatar
C821
If I'm driving yes, in traffic 200-210, are you getting 190 I'm traffic ?
Old Jun 29, 2021 | 08:30 PM
5632's Avatar
5632
Absolutely. When driving I am in the 170's. At idle or a stop light is when it might go up. Do you have a Z51?
Old Jun 29, 2021 | 08:56 PM
MitchAlsup's Avatar
MitchAlsup
Realistically, any water temp under 230ºF is acceptable, and any oil temperature under 270ºF is acceptable.
To Engine temp in traffic
Old Jun 29, 2021 | 09:00 PM
foo.c's Avatar
foo.c
I have in my Z51 and it hasn't even been triple digits here yet, but that was after spirited driving. Even after a cool down lap the fan in the driver's side stayed running for a while after shutting off.
Old Jun 29, 2021 | 09:18 PM
5632's Avatar
5632
The water temp has never gotten to 100? Something is wrong.
Old Jun 29, 2021 | 09:20 PM
5632's Avatar
5632
What degree thermostat is used in a C8 Corvette from the factory?
