Sponsored by: Wheel Design
Add oil?
Old Jun 17, 2021 | 01:39 PM
davelv's Avatar
davelv
Default Add oil?
Is it worth adding 1 or 2 ounces of oil when it shows 1/4" low on the dipstick?
Old Jun 17, 2021 | 01:44 PM
foo.c's Avatar
foo.c
If it's in the range you're good.
If I had an open bottle handy I might top it off, but I wouldn't bother otherwise.
Old Jun 17, 2021 | 02:19 PM
AzDave47's Avatar
AzDave47
No. If half way down maybe add a 1/2 quart, but foolish to add just a couple ounces to a system that holds 300+ ounces.
Old Jun 17, 2021 | 03:22 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Anywhere between the high and low marks is OK, but if I were going to be running it hard I'd make sure it's at least halfway between those marks. As long as it's halfway or higher, no need to worry at all.
Old Jun 17, 2021 | 07:21 PM
AzDave47's Avatar
AzDave47
FYI on my HCI LS7, setting the oil level at the middle hole with oil at 180* results in the oil at the top mark at 260*, so with the heat the oil expands. I have the 10.5 quart system. The earlier C6Zs have an 8 quart system and it is known those should be tracked with the oil at the top mark at 180*.
I am not sure how much the C8 LT3 engine varies based on oil temperature.
Old Jun 17, 2021 | 07:27 PM
Smuuth's Avatar
Smuuth
I apologize for this somewhat off topic question, but does the C8 engine hold 10 quarts the same as the LT4?
Old Jun 17, 2021 | 08:14 PM
AzDave47's Avatar
AzDave47
From 2020 owners manual
Capacities and Specifications
The following approximate capacities are given in metric and English conversions.
See Recommended Fluids and Lubricants 0 296.
Application
Capacities
Metric English
Air Conditioning Refrigerant For the air conditioning system refrigerant charge
type and amount, see the refrigerant label under
the hood. See your dealer for more information.
Engine Cooling System with Performance Package* 21.5 L 22.7 qt
Engine Cooling System without Performance Package* 20.5 L 21.7 qt
Engine Oil with Filter 7.1 L 7.5 qt
Fuel Tank 70.0 L 18.5 gal
Wheel Nut Torque 190Y 140 lb ft
All capacities are approximate. When adding, be sure to fill to the approximate level, as recommended in this
manual. Recheck fluid level after filling
*Engine cooling system capacity values are based on the entire cooling system and its components.
Old Jun 17, 2021 | 08:30 PM
Phil1098's Avatar
Phil1098
Application
Capacities
Metric English
And yet, when I did my own first oil change with filter, it took 8 full quarts to be full when fully warmed up and idling on level ground.
Old Jun 17, 2021 | 09:11 PM
AzDave47's Avatar
AzDave47
^^^ That's the best way, do the change, put in about a quart less, run it 'til it gets up to proper oil temperature and then check level per proper procedure and top off as needed. I wouldn't just pour 10.5 quarts into my LS7 without checking.
To Add oil?
