Sponsored by: Wheel Design
Brake Feel
Old Jun 26, 2021 | 03:46 PM
Italianfox's Avatar
Italianfox
Default Brake Feel
I've played around with brake feel in Z mode but quite frankly i notice little difference between tour, sport and track. Am I missing something?
Old Jun 26, 2021 | 03:52 PM
MitchAlsup's Avatar
MitchAlsup
Sensitivity in you foot ?!?
Old Jun 26, 2021 | 04:00 PM
Italianfox's Avatar
Italianfox
maybe i should drive barefoot
Old Jun 26, 2021 | 04:06 PM
Gator1969's Avatar
Gator1969
Sciatica may be in play!
Old Jun 26, 2021 | 04:51 PM
Stpete's Avatar
Stpete
Also keep in mind when disengaging Z mode it will default back to tour mode. So if you have your brakes, steering or suspension set aggressively be prepared for a immediate change back to tour settings. It could catch you off-guard if driving very aggressively and then disengaging Z mode.
Old Jun 26, 2021 | 11:36 PM
proeagles's Avatar
proeagles
Yes you are missing feeling in your feet. There is a clear difference between the modes, especially in a non Z51.
Old Jun 27, 2021 | 09:44 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I've had a similar issue for the 9 months I've had my C8. I was coming from a 2017 Grand Sport with 6 piston front calipers and vacuum brake booster. With the aggressive stops I make every day thought there would be more of a different feel in eBoost with various settings! I leave a 4 lane divided highway with often heavy traffic (especially this time of year with folks going and coming from Myrtle Beach) and turn into narrow rural roads. I brake hard so folks behind don't have to slow excessively for me (especially when there is a log truck going to the paper mill in the pack!)
Granted that 50/50 weight C7 GS had some nose dive and went to probably 75% dynamic weight on the front wheels BUT it stopped great and felt like it was. My C8 Z51 stops fine but the feel is different. Expected some difference as no nose dive and probably closer to 50/50 dynamic weight distribution after weight transfer. However on all 3 settings eBoost feels about the same.
I often drive in Z MODE Power set to Track and have eBoost set to Track, Steering to Sport. Love what I call Rev Match Music as it downshifts through 3 gears in the blink of an eye! Have no issue with the C8 (although larger brakes would probably be better) but surprised there is not more difference in eBoost brake feel at different settings. BTW also drive in MY MODE set to Sport with eBoost also set to track. Feels about the same braking as when in Z MODE.
I've posted this a few time but first I've seen the comment from another member or got input!
Old Jun 27, 2021 | 12:48 PM
Italianfox's Avatar
Italianfox
Based on your recommendation a while ago I also usually drive in Z mode with throttle set to track, brake feel set to track, NPP set to track, steering and suspension set to sport. But when I switch to tour mode the brake feel seems the same. I'm coming from a C7 Z-51 that i drove pretty much in sport mode and on occasion in track.
Old Jun 27, 2021 | 12:50 PM
Italianfox's Avatar
Italianfox
my feet feel fine on my Z-51 C-7.
Old Jun 27, 2021 | 01:33 PM
JerryU's Avatar
JerryU
Waiting for someone to say it feels much different in Touring, Sport and Track! And not normal braking when just cruising when braking hard as someone who Tracks!
Old Jun 27, 2021 | 01:51 PM
Racer86's Avatar
Racer86
did you set your preferences in Z mode?
Old Jun 27, 2021 | 02:29 PM
JerryU's Avatar
JerryU
Yep, as noted, have Power set to Track, eBoost set to Track (for the past ~4 months, had tried Sport.). I hand NPP set to Track, Steering set to Sport.
In MY Mode I also use set to Sport but eBoost to Track so eBoost is the same as Z Mode.
To Brake Feel
