I have been driving my 2021 Corvette for about 3 weeks now and moisture collects under the the pass. side floor mat. A spot about 8 inches in diameter in the middle of the floor . Could that have something to do with air conditioning
There is a simple solution to fix an AC condensate drain hose that is on that side! here is the Service Bulletin info: Chevrolet has issued a new Technical Service Bulletin #N212327740 for some owners of 2020 and 2021 Corvettes over an issue with the HVAC condensation drain hose. The bulletin states that these drain hoses may not be fully installed, which is causing water leaks in affected vehicles.
There is a post that shows it's a simple DYI issue if you want to do yourself.
