Sponsored by: Wheel Design
Tutorial request for removing upper control are bolts
Old Jul 2, 2021 | 11:54 PM
GMAC1's Avatar
GMAC1
Default Tutorial request for removing upper control are bolts
I wanted to swap the upper control arm spacers for the track alignment but as I was backing out the upper control are bolts it seemed like there was a lot of tension on the bolts/control arm? Are you supposed to but some jack lift pressure under the lower control arm before removing the bolts? Anyone got a video of how to remove the bolts safely? Thanks
Old Jul 3, 2021 | 09:58 AM
foo.c's Avatar
foo.c
Yeah, there's a big spring that supports the weight of the car. It's good you stopped before you got killed.
Put a jack under the lower control arm, usually under the lower ball joint is a good place.
Old Jul 3, 2021 | 10:03 AM
proeagles's Avatar
proeagles
What scares me is what else don't you know about doing this!
To Tutorial request for removing upper control are bolts
