Sponsored by: Wheel Design
V4 operation
Old Jul 9, 2021 | 10:15 PM
sprayer's Avatar
sprayer
Originally Posted by Spamburger_Hamburger
To be fair, they design engine and systems for this feature and if it wasn't good for the engine it would be there. I understand not wanting it if you can't control it, but they know what they're doing.
So gullible
Old Jul 9, 2021 | 10:23 PM
BJ67's Avatar
BJ67
Originally Posted by DSOMrulz
I guess since I've been driving manuals for nearly 50 years, that's not a problem for me. One could learn new tricks if staying out of V4 mode is that important.
I was telling you what I say to myself and call myself when I forget I am in manual mode. I also have been driving manuals for more years than I care to remember and maybe more than many. there is no comparison to driving a glorious manual versus driving a auto trans "especially paddles only" in manual mode. At least in my Camaro I can drive in manual mode with the shifter and not just the paddles. Thanks for sharing the manual mode info.
Old Jul 9, 2021 | 10:29 PM
BJ67's Avatar
BJ67
Originally Posted by Peppino Esposito
I have definitely experienced roof creak on super hot days with the ac on. Never a sound other than that.
Yes indeed , quiet otherwise. If the day is comfortable with the window open, I would not hear a creak anyway, but it seems quiet when the sun is gone on a hot day with the windows up a/c on.
Old Jul 9, 2021 | 10:35 PM
Gator1969's Avatar
Gator1969
Anyone else have trouble translating all the acronyms? What is MLSD?
Old Jul 9, 2021 | 10:41 PM
BJ67's Avatar
BJ67
Me too, but well over 50yrs. I have drag raced at the strip and the street with C5 manuals, C6 manuals, C7 manuals.
Old Jul 9, 2021 | 10:43 PM
BJ67's Avatar
BJ67
mechanical limited slip differential.
Old Jul 10, 2021 | 08:13 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Originally Posted by BJ67
So what is the way to go, track setting the engine trans in Z mode?
Range AFM Disabler
Old Jul 10, 2021 | 08:27 PM
BJ67's Avatar
BJ67
Originally Posted by DevilDog II
Range AFM Disabler
Glad you reminded me on the range Device, do you know for sure it works in the C8? If it does, that seems to be the way. Driving in Z mode with the trans set for track keeps it out of V4 mode but the trans stays in the lower gears even while cruising , you hardly even see 4th driving around down, that doesnt work for me, I need it to up shift.
Old Jul 10, 2021 | 09:16 PM
BJ67's Avatar
BJ67
Originally Posted by heisnuts
If you go into Z mode and set engine to track setting the engine will never go into V4 mode. Once you start up the car, you hit the Z mode button on the steering wheel and you are all set. It has become second nature to me now. As an added benefit Z mode allows you to customize so much more than just the engine so it has really allowed me to dial in the car to exactly how I want it and it is as easy as hitting the Z button after startup.
Just tried that today, how do you live with the very much delayed up shifts? if your cruising around town, it takes some MPH to get the car to up shift just to 4th and it will never up shift to 5th until you reach another MPH thresh hold. That doesnt work for me, any other methods or settings? other than the range device?
Old Jul 10, 2021 | 09:32 PM
heisnuts's Avatar
heisnuts
If I find the RPMs are too high for my liking, I just tap the upshift paddle on the steering wheel and all is well. Most of my 3,000 miles have all been back road country driving, but even in town I rarely find the RPMs to be too high for my liking before it upshifts.
Old Jul 11, 2021 | 08:09 AM
BJ67's Avatar
BJ67
I fiqured I could do just that, thanks for sharing. It would be like driving partially in manual mode, track mode and normal drive mode.
Old Jul 11, 2021 | 08:30 AM
JK 23112's Avatar
JK 23112
That AFM seems to cause consternation and worry - probably for good reason. GM has had myriad issues with it in thei Silverado/Sierra V8 engines.........which are similar in design & architecture to the small-block V8 used in the Corvette. I am part of the "can't be a good idea" crowd too.
My 2017 Stingray has a manual transmission, so no V4 operation unless the car is in "Eco" mode. My girlfriend has a 2019 Stingray with the automatic, so it does go into V4 by default. Right after we bought her C7 brand new, I purchased a Range AFM bypass device, which plugs into the OBD-II port. It prevents the engine from going into V4 mode altogether.
To me, it is not worth saving 1 to 1.5 miles per gallon and end up risking long-term engine damage. Our Corvettes still get great fuel economy in V8 mode anyhow and we don't drive enough miles in them to worry about squeezing a few more miles per fill up. We have four-cylinder daily drivers for that purpose.
Best of luck to you C8 owners and maybe the Range AFM bypass device might work on your cars too. I suppose their web site could give you the proper information. The price was $179 just over two years ago & is worth it for peace of mind.
Save the wave!!
Old Jul 11, 2021 | 05:07 PM
  #33
DevilDog II
Oldtimer
I don't know if it works on the C8. You might want to give Range a call and ask them.
Old Jul 11, 2021 | 05:08 PM
  #34
DevilDog II
Oldtimer
Save the wave!!
Old Jul 29, 2021 | 02:31 PM
  #35
meridock's Avatar
meridock
I have aftermarket exhaust - if you think v4 mode is not great in stock form, it is not bad. the sound with Aftermarket is really impacted. I have the AWE Touring exhaust system and when in v4 mode the sound makes a rude fart-ish sound. the stock exhaust masks this pretty well
Old Jul 29, 2021 | 04:05 PM
  #36
BJ67's Avatar
BJ67
Yes, I put after market mufflers on my 2021 Camaro LT1 with the 10 speed auto, makes the transition in and out of V4 mode so much more noticeable and just hated it more. I had it tuned out and have AFM valve simulators, the car is now wonderful.
Old Jul 29, 2021 | 05:26 PM
  #37
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Regarding the C8 V4 operation, is there anyway other than driving in M mode that will stop V4 mode from happening . I understand that whatever the tricks are, the car always defaults back on a restart. Going in and out of V4 mode I agree is virtually seamless, but I would rather not have it in operation.
while I am at it , what about roof creak when the car is hot on a hot sunny day? I am thinking of putting lube on the 3 latched areas.
Yep, use Z Mode Power set to Track! That is the way I often drive. In my case with MRC I don't have to live with Track shock settings. If you want you can set Ride to Touring. Set NPP, Steering, eBoost wherever you want. It's like driving another more responsive car.
Here are some details AND a great video by a forum member. I drive in Z MODE and MY MODE where it does go into V4 and will use 7th and 8th gear where Z Mode won't!
  • The car will upshift at much higher rpm than when in TOURING, SPORT or MY MODE.
  • It will seldom shift past 5th gear (or 6th if going >73 mph. Note 4th and 5th are OD ratios, like 6th, 7th and 8th) providing engine torque with modest throttle increases WITHOUT downshifting.
  • It will not go into V4 mode.
  • When braking, it will downshift at higher rpm and rev match makes it perfectly smooth in each gear.
  • Note, if desired you can still use the shift paddles. So if it's in 4th or 5th and your just cruising, pull the upshift paddle and you can shift to 5th, 6th or 7th. If making an aggrieve turn you can downshift at whatever rpm you'd like as you brake before the turn. But you'll probably find when in Z MODE with Power set to TRACK it will downshift at high enough rpm with aggressive braking. Frankly in my rural area I drive my manual shift 2014 Z51 and My 2017 Grand Sport about the way Z MODE power set to track operates. I was never in V4 mode (albeit when driving in MY MODE the DCT makes the transition perfect) and never used 6th. Only used 7th when on the interstate, which was very seldom.
Good video describing what I said in words by a forum member:
https://www.youtube.com/watch?v=RI9M...annel=jrock702
To V4 operation
Old Jul 29, 2021 | 07:29 PM
  #38
z51vett's Avatar
z51vett
Have you every had the lifters fail 6 weeks without my Z06 ask me how I like it l bought a device to cancel it out
Old Jul 29, 2021 | 07:32 PM
  #39
BJ67's Avatar
BJ67
Originally Posted by z51vett
Have you every had the lifters fail 6 weeks without my 06 ask me how I like I bought a device to cancel it out
Yeah, thats the best way, tune it out or off.
Old Jul 29, 2021 | 08:06 PM
  #40
Michael T*'s Avatar
Michael T*
Range does not currently have an AFM disabler for the C8. I had one on my C7.
