Sponsored by: Wheel Design
Engine lighting complete
Old Jul 15, 2021 | 10:43 PM
fastrx7man's Avatar
fastrx7man
2022 C8 of the Year Finalist - Modified
Modified C8 of the Year 2021 Finalist
2020 C8 of the Year Finalist - Modified
Default Engine lighting complete
Last night I installed a light in the engine bay. 20+ different colors.
Took less than a hour and cost less than $20. Remote is in the car.
Old Jul 15, 2021 | 10:51 PM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
Looks GREAT !
Are you running off a portable battery, or are you tapped into 12V ? If you tapped into 12V, WHERE did you choose to get juice from ?
I've got a set of LED's ready to go as well, but haven't gotten into looking for a 12 Volt source that is hot all the time.
Old Jul 15, 2021 | 11:36 PM
That actually looks really good.
Old Jul 16, 2021 | 03:19 AM
ABHMD's Avatar
ABHMD
Looks great, could you describe the install, thanks
Old Jul 16, 2021 | 03:52 AM
moundman's Avatar
moundman
I like it. Nice job!
Old Jul 16, 2021 | 04:42 AM
Tim0shel's Avatar
Tim0shel
I love Green!!! Looks good and like others had already asked about the install etc.
Old Jul 16, 2021 | 09:47 AM
RT82's Avatar
RT82
I discovered a link on Facebook on wiring OEM Engine Bay lights to garage door openers, I did this and it works great. Sorry I do not have pics. I already had the OEM lights installed so all I had to do is order the device mentioned in the post ($14.00 on Amazon) and then pull off the left side panel behind the drivers side and splice the device wires into the wiring harness, then program the visor buttons. This is not my idea....after my install I sent a thank you to Gilbert Hernandez thanking him for the post. This is a very easy way to light the engine bay by just pressing the visor buttons or the remote. OEM lights obviously are not overbearing, it looks great when the car is parked during dark hours. This is the link: https://www.facebook.com/groups/C8.C...4543303216575/
Old Jul 16, 2021 | 10:43 AM
johnodrake's Avatar
johnodrake
Moderator
Where there's will there is a way. Great job!
Old Jul 17, 2021 | 10:56 AM
fastrx7man's Avatar
fastrx7man
Answers to the questions. My goal was to be able to add the lights, be able to control them from inside or outside the car with the car running or not running. I also wanted to be able to remove it and go back to stock. I bought a 11 inch LED light strip off of Amazon. It's powered by 6 AAA batteries. It came with a white housing so I painted it black. I then used high heat double sided tape to mount it to the top of the hatch. I considered screwing it into the plastic part of the hatch but then there would be two holes if/when I removed it. I will monitor the tape but so far no issues.
As mentioned it was a quick install and didn't cost much.
Below is a picture of the light installed.
Old Jul 17, 2021 | 11:08 AM
Amoreloba's Avatar
Amoreloba
Looks great! The ones you bought, did they have a setting for brightness too? I have a real dumb idea to get an OBD II reader hooked up to an arduino and read the engine rpm’s then tie brightness to that. Ty for the idea at least! 😁
Old Jul 17, 2021 | 11:22 AM
fastrx7man's Avatar
fastrx7man
Thank you..
There's a button on the remote to increase the brightness.
Old Jul 17, 2021 | 12:20 PM
gmarcucio's Avatar
gmarcucio
Looks great!!! Does anyone know if GM offers the light kit at an add on accessory?
To Engine lighting complete
