Sponsored by: Wheel Design
Inner Grill Guards
Old Jul 23, 2021 | 09:42 AM
V1lla1nous's Avatar
V1lla1nous
Default Inner Grill Guards
Has anyone had any luck hiding the ties on the inner guards on the front bumper? The outer seem to be pretty hidden once you remove the front grill insert.
See pic below (Not my car)
Old Jul 23, 2021 | 10:10 AM
Spamburger_Hamburger's Avatar
Just synch them from the back, no one is ever going to notice that zip tie unless they are down on the ground looking for them, like the picture you posted.
Old Jul 23, 2021 | 10:21 AM
papillion's Avatar
papillion
Default Hmm?
Teenage angst over a zit on my nose. Mom said if someone looks that close, they are a very good friend. And don't care.
Old Jul 23, 2021 | 10:22 AM
V1lla1nous's Avatar
V1lla1nous
OCD is real. It's more about me and less about everyone else.
Old Jul 23, 2021 | 01:07 PM
carriccp's Avatar
carriccp
When I had those on mine, the inner portion was wedged behind the carbon flash bumper piece and the outer side was zip tied behind the body color portion of the bumper. No zip ties visible.
Outer grill guards also had no visible zip ties anywhere.
Old Jul 28, 2021 | 01:25 PM
mazurekd's Avatar
mazurekd
So, did you remove the grills for a reason? Different ones? More air?
Old Jul 28, 2021 | 02:07 PM
gmarcucio's Avatar
gmarcucio
Did you sell the car?
Old Jul 28, 2021 | 03:44 PM
NextOne's Avatar
NextOne
Search his username and you'll see he's bought and sold two C8's.
I installed them, but was not able to completely hide the zip tie ends like I did with the outer grills (behind the winglet inserts). But you have to get on your hands a knees to see them. Pick your poison: practically invisible zip tie ends or highly visible, bug-clogged radiator fins.
Raised-car view of radiator grill covers installed with zip ties
Old Jul 28, 2021 | 04:16 PM
johnnycat500's Avatar
johnnycat500
Unmodified C8 of the Year 2021 Finalist
@NextOne I installed the pargon grill guards, But could you share where to bought the brake intake grills from, I would like to purchase them. Thanks!
Old Jul 28, 2021 | 05:40 PM
TexasMark's Avatar
TexasMark
I did the "cut your own grill" approach, oversizing grills a little to reduce the need for black cable ties. All ties are hidden, at any practical viewing angle.
The inner grills (cut extra long) are press fit into the center part of the car, and wire tied on the outer side where you cannot see them.
The outer grills were installed as described elsewhere in this forum, so that no cable ties are visible. The procedure involved removing that black carbon flash T-member(winglet inserts). When I re-installed the T-member, I reversed its attachment bolts so they can be tightened from the front, and using the original clip nuts like regular nuts (because in reversing the bolts, there was no way to clip the clip nuts to anything).
No black cable ties visible.
Old Jul 28, 2021 | 05:55 PM
Raz0r's Avatar
Raz0r
I installed the Paragon grills also, no zip ties used. they bolt into the factory locations. Clean look and seem effective.
Old Jul 28, 2021 | 06:17 PM
C8J's Avatar
C8J
Ditto. I also purchased the ones for the 2 side inlets.
Old Jul 28, 2021 | 07:44 PM
tsigwing's Avatar
tsigwing
and double sided tape. That and the cost persuaded me to not use it.
Old Jul 28, 2021 | 10:44 PM
johnnycat500
I did too, Pargon told me they will be back in stock 2nd week of August.
Old Jul 28, 2021 | 11:03 PM
NextOne's Avatar
NextOne
I assume you mean the two inboard front grills. Purchased all from CustomCarGrills.com.
Old Jul 29, 2021 | 12:28 AM
carriccp's Avatar
carriccp
No, ran the same Custom Car Grills inserts on both cars. No issues with airflow.
Yes.
What he said. If/when I get another, I'll run the same screens on it.
Old Jul 29, 2021 | 12:48 AM
Raz0r's Avatar
Raz0r
Not sure about any tape, but you get what you pay for, that is why they have the zip-tie option.
Old Jul 29, 2021 | 07:01 PM
michel lussier's Avatar
michel lussier
where i can find and buy it, and the plan (design) and instruction for installation
thanks
Old Jul 29, 2021 | 07:04 PM
johnnycat500
Yes, thank you for the info.
To Inner Grill Guards
