How I’d Reprogram DCT Algos
Good & bad on MPG: So I noticed how impressive—awesome— my highway MPG was..even at speeds above where MPG typically peaks. Most cars I’ve driven optimize in low/mid 60’s…looks to me like the sweet spot is around 72.
The bad news is..l was disappointed at the crappy mileage it gets driving conservatively even coasting around town. Sooo..I noticed the car switches out of 4 cylinder mode INTO 8 cylinder mode—as your speeds varies higher OR LOWER….like when your speed DROPS from 35 mph to 10 mph to stop. Gee, I REALLY needed those 8 cylinders to kick In for that powerful ride from 35 mph to 10 mph. It DOES.
So Mr. Engineering idiot me suggests GM change: DCT, when operating in 4 cylinder mode…STAYS in 4 cylinder mode when speed declines. It returns to
8 cylinder mode when..it’s needed to accelerate at all.
Might this be the algo change reportedly coming in MY 2022. GM says a change is coming to increase MPG. This would seem like common sense unless I’m missing something or doing something wrong which is highly likely
I totally get why you might not want DCT to EVER deactivate 4 cylinders. But if we’re going to play that game…why re-activate those cylinders when the car slows down?
I didn’t know the fuel use can be “cut off”….unless there’s a lag I noticed a simultaneous drop in “current trip” mpg. If you drive the car consistently at ANY speed it gets great MPG. Any variation at all plus/minus eats into it considerably. Much MORE so than any car I’ve driven in 40 years.
Again this is NOT a priority for me, it’s just the latest in a myriad of unique things I’ve learned each day of usage..most of which is pleasantly surprising.
If you want to get max mpg drive like you have a raw egg between your foot and the gas pedal. (A trick from the old Mobil Economy Run that operated from 1936 to 1968- wonder why it stopped?) Plus like I did when prices were sky high in the early 1980s and we could only buy gas every other day based on the last number on your license plate. The 15 gallon tank on CJ5 V8 Jeep could my not make it to LaGuardia from CT (where I lived and where Corporate Office was located) and back on 1 tank of gas! Since I traveled about every week bought a 1.4 liter Dodge Colt so I didn't have to stay out of town to come home on a day I could buy gas. (Looks like we're heading there again!) Recall making a bet that I could get 50 mph! Won, but that required driving using another Mobil Economy Run trick I had on my 1st car a throttle cable! Although the Colt didn't have one or cruise control, needed to let it slow down going up hills keeping the throttle fixed. Cruise control is NOT the best for gas mileage. Want to keep it in V4 don't use more throttle when going up a slight incline- let it slow down. Foolish way to drive a C8 but will help!
Now I have had my car a year! Never track mpg when I'm driving. Not what I bought a Corvette to do. In fact do keep track of gas mileage on an Excel spread sheet when I buy gas. I often drive in Z Mode Power set to Track. Never goes in V4 and will only shift to 6th over 73 mph. Never in 7th or 8th.
It drives like a Corvette should in my rural area and they way I drove my two manual trans C7's. See this video: https://www.youtube.com/watch?v=RI9M...annel=jrock702
For fun to see how much mpg I was losing I used MY MODE set to Sport for a tank full where it uses all gears and goes into V4. For that tankful I got 2 mpg better mileage. Now that is zero Interstate driving just my normal back roads 20 miles into town and 20 back. BUT not driving like an old man (heck I'm only 78!) For 2 to 3 mpg I'll drive where the C8 does its best as a sports car, Z MODE Power set to Track!
Easy way to see that, is on a hilly 40-50 MPH road, with Cruise on. Part of that is when engine is braking going down hill, V8 engine braking then V4 in the Flat, then V8 up the next hill. Best Gas mile, Best for not Lugging Engine, and Dam smooth doing it.
Without the V4/V8 showing on the Hud I wouldn't know it. as I can't Butt feel the Swaps....
Thanks SO much for your help on this. And thanks for the many other things I’ve learned from you on this board. Your generosity is much appreciated.It will be interesting to see how GM tweaks the algorithms for MY 2022. They’ve said it will result in better MPG. My assumption is more use of 4 cylinders but perhaps there’s a magical way to get more out of “8” in certain situations….
And apparently DSO is also an idiot like ME: “ALL modern manual transmission cars cut the fuel completely when decelerating in gear”,
Please enlighten Mr. condescending jerk. TIA.
You want me to be a FANBOY to pass your litmus test? Ok, it flies, iit’s refined, its interior is way beyond Corvette standards, it takes off like a rocket. It’s easily best sports car ever built in USA. And a better bargain.
There. Do you feel better? Is that the context you need for minor issues?
