Our 21 has about 2000 miles on it. I wash it every Wednesday evening. I took the car out this morning and after a few miles steering was feeling weird. When I applied the brakes to turn into a parking lot I got the shakes like warped rotors. When I got out of the car my right front brake was smoking. The rotor was chewed up and over heated. The left front looked like I took a arc welder to the rotor with a obvious high spot of contact. When I drove home, the brake peddle felt like it was on a spring. Rear brakes are fine and look like new. Going to the dealer Monday morning. This is the second problem. The first problem is I can't drive the car enough
Digital glitches and fluid leaks are one thing... brakes entirely different, as far as I'm concerned. I wish you well at the dealership. Do let us know the rest of the story, please, when you find it out.
First time I read a problem sounding like what you found from C6, C7 or C8! May be eBoost activating when it should not BUT it affects all brakes not one. Let us know what the dealer finds.
SIDBAR: One issue is washing every Wednesday! I always drive my car a short distance after washing so the rotors don't turn brown from rust! Recall with my C7 it started to rain when I was just finished washing pulled it directly into the garage. The rotors brown with rust except where the pads were. When I backed out of the garage the next day there was a loud nose as the pads came lose from the rotors. Recall some others reporting that as well. Also, if allowed to form that iron oxide it comes off when first driving BUT fine brown dust just goes on the wheels. May have nothing to do with your issue - just an observation.
That is my concern. After I wash the car I use the leaf blower to dry and park the car. I don't like to drive after a wash because the water that might be in a crack or behind moulding and blow out leaving a water spot
I always do a very short drive after wash. Especially the z51 needs it as I have read on these forums that the brakes are different and have a tendency to show that rust that Jerry mentioned.
After washing and drying, I take my car and drive around in a circle a few times on my cul de sac. I park the car back in the drive and blow-dry off any water that has seeped out of cracks with my Master Blaster. This works well to prevent spotting from water that seeps out the cracks and crevices in the car and it doesn't get the car dirty,
A piston freezing in a caliper can happen in any car. It's certainly not common, but I've seen it in other cars, though generally not at such a low mileage. GM should replace all the affected parts under warranty without any hassle. Other than waiting for parts, maybe.
Reminded of a fun post where someone was complaining about the rust on his early C7 Z51 after washing, said he never saw that before. (Agree some rotors are coated but the Z51 for max performance are not.) But I asked if this was the first car he washed himself and all prior went to a car wash? He said yes it was. Yep after a car wash you drive the car. Doesn't take much to heat the rotors and dry them off. I just go a short distance, apply the brakes and return to the driveway to pick up water that drips from the mirrors, spoiler and some on the wheels. That is also when I apply tire dressing, now just 303.
Strange that both left and right were both affected. I always do the short drive after washing, once around the block does it.
Don't know if this is your problem, but I have had a similar issue on a C4 (but much less severe) and on a V45 Interceptor (would almost lock up driving around the block ~1/4mi). Both happened to just the front (Yea, Motorcycle has totally independent F/R Master Cyls). If the "relief" in the MC (that allows brake fluid to return to the MC as the brake fluid temperature rises) is plugged, the brake fluid will build pressure, engaging the brakes. As the brakes engage the temp rises more, causing the pressure to rise more and ............... you get the idea. I would be surprised that a "new" MC would do this, but it would explain why both Fronts were Hot (as opposed to what a caliper would do).
I took the C8 to our local dealer for the brake issue. They found the rotors warped and re surfaced them and installed new pads. They couldn't find the reason they overheated. They also ordered parts for the lift recall and checked the recall for the infotainment system going black in cold weather.
The car cam back to me detailed and spotless. I am very happy
Is this the blue cap or something new? I did not see a recall for my 21 with front lift. Thanks
Customer Approved Services
Service
Front Lift System Reservoir Cap Leak - Expires with Base ...
Comments: Comments: N212330480 -Front Lift System Reservoir Cap Leak - Expires with Base ...
Airbag Light May Not Indicate Malfunction
Comments: Comments: N212338110 -Airbag Light May Not Indicate Malfunction
Brake System Diagnosis
Comments: Comments: CUSTOMER STATES FRONT BRAKES SEEM TO BE STICKING. WHEN APPLYING BRAKES FRONT WILL SMOKE, STEERING WILL SHAKE, AND CAN VISUALLY SEE ROTORS BEING BURNT/GROOVED. PLEASE CHECK AND ADVISE.
Infotainment Screen Remains Black In Cold Temperatures - ...
Comments: Comments: N212327470 -Infotainment Screen Remains Black In Cold Temperatures - ...
