Sponsored by: Wheel Design
Phone volume
Old Aug 3, 2021 | 09:21 PM
WardNH's Avatar
WardNH
Default Phone volume
Maybe I am missing something, but I cannot get my phone volume loud enough. When I have the top down, even with the windows up, I need to pull over to hear the person on the phone through the car system. I crank the volume on the phone, and I crank the radio volume that then shows the phone volume on the info screen as full blast. But I can barely hear the person on the other end. It has been multiple phone calls, different people and phones.
Is there any other adjustment? In my C7 I could go down the highway with the roof off and windows down and have a conversation on the phone through the car. In the C8 I can't hear it at 30-40 mph with the windows up...
Old Aug 3, 2021 | 10:09 PM
dohabandit's Avatar
dohabandit
Android or IOS?
CarPlay or BlueTooth?
If bluetooth, you might try checking the audio protocol / CODEC being used and try a different one. On android this is done via developer options.
DEVELOPER MODE
  1. Go to the settings menu and click “About phone”
  2. Scroll down to the bottom where you see “Build number”
  3. Tap it seven (7) times. Android developer settings are now enabled.
  4. Go to the settings menu again and click System->Developer options->Bluetooth Audio Codec.
  5. Choose your audio codec of preference.
Old Aug 3, 2021 | 10:38 PM
WardNH's Avatar
WardNH
Originally Posted by dohabandit
Android or IOS?
DEVELOPER MODE
IOS
Bluetooth. I have Carplay turned off, hadn't thought to try that...
Old Aug 4, 2021 | 08:51 AM
WardNH's Avatar
WardNH
Just switched to Carplay. Still far too quiet to hear when the car is moving with the top down...
Old Aug 4, 2021 | 09:14 AM
RandelB's Avatar
RandelB
Unfortunately, I do not have my C8 just yet. However, on my 2021 Trailblazer, the infotainment center is very, very similar, if not exact. The phone volume can only be adjusted while in use. While ringing, or while talking, the volume buttons on the steering wheel are used to change the volume. It gets trickier on the guidance volume, since the commands are quick. You have to be ready and anticipate.
Old Aug 4, 2021 | 09:31 AM
papillion's Avatar
papillion
Default Hmm?
Pulling over and stopping to have a phone conversation seems the perfect solution. For you and for me.
Old Aug 4, 2021 | 09:35 AM
WardNH's Avatar
WardNH
Maybe perfect for you, but not for me.
Old Aug 4, 2021 | 04:30 PM
thrilled's Avatar
thrilled
should be a law in every state no phone use while the car is moving. You wouldn’t believe all the accidents from perfect drivers using the phone
Old Aug 4, 2021 | 04:31 PM
Broken Halo's Avatar
Broken Halo
I've noticed something strange. I always have my iPhone set to max volume but after I get home from a drive where it linked up to my car via Bluetooth the volume setting on my phone has turned itself almost all the way down. I read a post a while back about someone with the same problem but can't find it or if he found the problem/solution.
Old Aug 4, 2021 | 04:40 PM
Day11's Avatar
Day11
this a GM thing. My Silverado and C8 do the exact thing you are describing. I have to remember to adjust the phone volume once I leave my vehicle. It is very frustrating as I am missing calls because I often forget
Old Aug 4, 2021 | 04:45 PM
WardNH's Avatar
WardNH
That is your opinion and you are entitled to it. I'm just trying to get a feature in my new car to work.
Old Aug 4, 2021 | 05:26 PM
Broken Halo
I wonder what causes that??? I'm sure there's a work around if someone can just figure it out. Same problem here...if I don't remember to check my phone and turn the volume back up I miss calls.
Old Aug 4, 2021 | 05:41 PM
Vet Interested's Avatar
Vet Interested
It’s a shame you come in here to ask for help and end up getting preached to.
Old Aug 4, 2021 | 05:43 PM
Red Mist Rulz's Avatar
Red Mist Rulz
I have no issue with phone volume, ringer or voice, with my Android phone. Nor does the volume get lowered when I get out of the car. Have you tried the suggestion in post #5?
Old Aug 4, 2021 | 05:53 PM
Broken Halo
Maybe there's something about an Android that doesn't let that happen? I don't see a suggestion in post #5 related to resolving the problem @Day11 or myself are experiencing.
Old Aug 4, 2021 | 06:41 PM
WardNH's Avatar
WardNH
Figured out that my phone wasn't connecting through CarPlay. Fixed that, and now the phone comes through Apple CarPlay loud and clear with plenty of volume to spare at highway speeds with the roof & windows down. When I turn CarPlay off and bluetooth the phone, it is barely audible at 30-40mph.
Not sure why bluetooth is so quiet, but glad I can hear the phone through CarPlay when needed.
Thanks everyone for the suggestions.
Old Aug 4, 2021 | 06:51 PM
Brett_A's Avatar
Brett_A
Also, passengers in the car NOT allowed to talk to the driver law should also be passed.
To Phone volume
Old Aug 4, 2021 | 09:47 PM
direct007's Avatar
direct007
Old Aug 4, 2021 | 11:55 PM
johnodrake's Avatar
johnodrake
Moderator
No eating hamburgers or drinking coffee either
Old Aug 5, 2021 | 02:18 AM
bill-sj's Avatar
bill-sj
and BJ's are out of the question. difficult anyways with the "wall" in the C8. ;-)
