Sponsored by: Wheel Design
What is5V7
Old Aug 13, 2021 | 04:16 PM
JDIllon's Avatar
JDIllon
Default What is5V7
What is included in 5V7 splitter and side scoops? And what is the price? Thanks JD
Old Aug 13, 2021 | 05:00 PM
A10Driver's Avatar
A10Driver
8th Gear
On my 2022 price builder list I show 5V7 as Ground Effects, Black. (no further details) price $715.00
Old Aug 13, 2021 | 07:32 PM
rawbar's Avatar
rawbar
From Chris Lindamood (I emailed him about 5V7) In regards to the 5V7…those are another version of the ground effects it appears (just painted black). GM really hasn’t released anything on them yet and they do not appear in the order workbench when building a 2022 order. I would bet though that they are going to be pretty hard to get as all of the ground effects and even the rocker covers from GM have been limited. Most of my customers are just buying aftermarket ones as they seem to be a little better priced for the same quality as OEM.
FWIW, I ended up ordering the ground effects and high wing from American Hydrocarbon to save some $$$, rather than order the wing from chevy. Plus I went with the AC option of painting the winglets and leaving the rest black
Old Aug 13, 2021 | 07:53 PM
Zymurgy's Avatar
Zymurgy
Moderator
At $715 these are undoubtedly just molded black plastic (composite) version of the ground effects (probably textured like their other molded items - like the standard Z51 front splitter and the STI rocker extensions). Both 5VM (exposed carbon fiber) and 5W8 (carbon flash painted carbon fiber) are $4k-$5K.
Old Aug 13, 2021 | 11:35 PM
C6DRYVR's Avatar
C6DRYVR
On the 2022 visualizer you can select the "Black ground effects" under the "exterior accents" tab. That option doesn't have the wing like the carbon fiber or painted flash. Just a black blade and black front splitter. I plan to order the low wing that comes with a splitter, but also want a side skirt or rocker or whatever the hell you call it with a wing. Would like everything done when I pick up so will ask my dealer what is easiest to make that happen.
https://visualizer.chevrolet.com/ui?...US&channel=b2c
To What is5V7
