Sponsored by: Wheel Design
Checking the oil - C8 Convertible
Old Oct 9, 2021 | 04:57 PM
manecda's Avatar
manecda
Default Checking the oil - C8 Convertible
Unable to open tonneau cover on my convertible to the check oil. I followed instructions on page 37 of owner's manual. Engine idling, top and trunk closed, vehicle in park. Using the key fob, I depress the lock button followed by depressing and holding the convertible top op button. Tonneau cover doesn't open, Any suggestion on what I could be doing wrong? Going out will check back for any responses on return, Many thanks to this forum
David
Old Oct 9, 2021 | 05:03 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
Engine has to be off, it’s a dumb system. I use the switch in the door and simply release it after the tonneau opens, get out, check oil, get back in, close the tonneau, and then shut off the car.
Old Oct 9, 2021 | 05:29 PM
Andybump's Avatar
Andybump
Just checked this again on my 2021. Put the top up. Remote start the car. Now the engine is running. Push lock again and then the top button, Tonneau opens. Check oil. Push lock again and then top button. Tonneau closes, and engine shuts off. While I am not sure that extra pushes of the lock button are necessary, it did not seem to respond until I did that. In any case, it can be opened with the engine running.
Old Oct 9, 2021 | 06:29 PM
manecda's Avatar
manecda
Thank you 16falcon, While at idle, I used the switch in the door to open the tonneau to check and them close it. Then turned of motor.
and Andybump. Used your instructions and they worked too.
Forum members are extremely helpful
Sidebar:
I was under the impression that the motor had to be running in order to get an accurate check of the oil level since checking it cold would give an inaccurate reading
Old Oct 9, 2021 | 06:41 PM
Andybump's Avatar
Andybump
Running and warm.
Old Oct 9, 2021 | 07:15 PM
Nelag's Avatar
Nelag
Yes, motor needs to be running and warm to get correct oil level check. Not cold and off. Just the opposite of a normal oil checking process.
Old Oct 9, 2021 | 10:06 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
I hadn’t tried it using the remote start. But when pulling into the driveway, with the engine running, and then getting out to check the oil, the tonneau will not open with the fob on my car. Even if it will work after remote starting, I think it is dumb that I would need to shut down the car, get out, immediately do a remote start and then open the tonneau or open the tonneau and then do a remote start. Easier just to open the tonneau with the door switch, check the oil, get back in put the tonneau down and shut off the engine.
Interesting that you said that you could close the tonneau with the engine running, the first step in the manual says it must be off:
Closing the Tonneau Cover — Engine Access Function
1. Make sure the vehicle is off
Old Oct 9, 2021 | 11:21 PM
mazurekd's Avatar
mazurekd
Must try tomorrow.
Old Oct 10, 2021 | 09:19 AM
ea327's Avatar
ea327
Banned Scam/Spammer
Guys, it's not rocket science. With the engine running in park, top up. Hit the top down button until the tonneau cover is sticking straight up. Check the oil, then either continue to put the top down or put it back up. done.
Old Oct 10, 2021 | 06:28 PM
CP's Avatar
CP
Why isn't there an electronic oil level sensor like those on other high end cars?
Old Oct 11, 2021 | 07:59 AM
Broken Halo's Avatar
Broken Halo
I've had a problem with my HTC using the FOB where I have to go thru the 'Push Lock', 'Push and Hold Top Down' sequence a second time to open my tonneau cover.
To Checking the oil - C8 Convertible
