Sponsored by: Wheel Design
Side scoop extensions
Old Oct 27, 2021 | 05:49 PM
Cenzoooo's Avatar
Cenzoooo
Default Side scoop extensions
Now that the "big nasty" has been seen, I can't help but think they really cleaned up the scoop profile compared to the Stingray. The backwards boomeranged always kind of bothered me on my car.
Sketch monkey made a vid breaking down the good and bad
https://youtu.be/DsCIDefL27o
Here he points out a good sxs comparison of what I'm talking about.
so I did a couple of crude sketches on my phone over a couple pics of my car.
So why hasn't aliExpress fabbed up an extension for the side scoop yet? It should be easy enough to make a direct replacement for the piece on the fender without changing the door trim at all.
Popular Reply
Oct 27, 2021, 08:34 PM
Avanti's Avatar
Avanti
Both are still hokey and only acceptable if painted body-color.
Old Oct 27, 2021 | 06:23 PM
Kevin A Jones's Avatar
Kevin A Jones
The introduction of the C8 Z06 should really create a sales boom for the Corvette Aftermarket Parts companies trying to turn all Stingrays into Z06 look-a-likes.
Old Oct 27, 2021 | 06:25 PM
Majestic94's Avatar
Majestic94
Sketch monkey made a vid breaking down the good and badhttps://youtu.be/DsCIDefL27o
The Z06’s is larger and integrated into a much larger fender. How do you figure that’s a bolt in replacement?
Old Oct 27, 2021 | 06:46 PM
Cenzoooo's Avatar
Cenzoooo
The Z06 has more body for sure, but the carbon flash boomerang trim on the Stingray is removable and can be replaced with a larger forward sloping one.
It would obviously be an add on as opposed to the body integrated wide body, but it would still improve the profile.
Old Oct 27, 2021 | 06:53 PM
Cenzoooo's Avatar
Cenzoooo
Here's a removal vid for the boomerang on the fender.
It should be as easy as removing one and replacing with a larger one.
Old Oct 27, 2021 | 07:14 PM
Majestic94's Avatar
Majestic94
Sure it’s removable, but you’re trying to replace a boomerang with a shark’s tooth. The two shapes aren’t interchangeable.
Old Oct 27, 2021 | 08:34 PM
Avanti's Avatar
Avanti
Old Oct 27, 2021 | 09:10 PM
Amoreloba's Avatar
Amoreloba
Barring some actual bodywork to the panels to accommodate a true Z06 shaped intake outline, I think your best choice would just be a vinyl that buds right up against it. Simple, inexpensive, easy to change. Go get that eyeliner wing.
Old Oct 27, 2021 | 10:46 PM
QuikAF's Avatar
QuikAF
Boomerang > WishBone
Old Oct 27, 2021 | 10:51 PM
Probably won't be too long before the aftermarket gets rolling on the newest model look alike parts. Seems like it happens with every generation.
Old Oct 27, 2021 | 11:34 PM
NextOne's Avatar
NextOne
I ordered body-colored boomerangs on my AW coupe because I just don't care for how the black ones break up the design flow. That said, I think the ones on the Z06 look good.
Old Oct 27, 2021 | 11:45 PM
SingleTrackMinded's Avatar
SingleTrackMinded
OP: Thanks for posting.
I think the gentleman doing the sketch nailed it on furthering some key design improvements on the C8. I also agree with him on his assessment that the Corvette design team did make positive improvements and and solved some issue I too had with the C8 stingray design.
I like seeing the evolution.
Old Oct 28, 2021 | 10:16 AM
Cenzoooo's Avatar
Cenzoooo
Here's an old rendering of the scoop before the official release. It is a tidier look than what we have.
Old Oct 28, 2021 | 06:33 PM
Majestic94's Avatar
Majestic94
It’s just a painted boomerang
To Side scoop extensions
