Sponsored by: Wheel Design
The Check Mark
Old Nov 17, 2021 | 08:02 PM
godzilladude's Avatar
godzilladude
Default The Check Mark
OK, I know I'm an idiot. I'm setting up all the options and selections on the new ride. And several times the DIC says as an option I can push the "check mark". Or whatever one would call a check mark in a circle. Trouble is, I don't see no check mark anywhere.
When it says to push that, where is it??
Thanks.
Old Nov 17, 2021 | 08:05 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Read the manual. I bet it is in there.
Old Nov 17, 2021 | 08:20 PM
Bluehinder's Avatar
Bluehinder
Press OK
Old Nov 17, 2021 | 08:33 PM
gdb069's Avatar
gdb069
I had the same problem. Where is the check mark especially asked if I want to simplify the screen. Turns out the check mark is the thumbwheel on right lower steering wheel.
Old Nov 17, 2021 | 10:39 PM
Hope you get it figured out.
Old Nov 17, 2021 | 11:54 PM
Zormecteon's Avatar
Zormecteon
That works for everything EXCEPT the front lift memory check mark .... which is to the left of the thumb wheel
Old Nov 18, 2021 | 07:45 AM
BIG Dave's Avatar
BIG Dave
Old Nov 18, 2021 | 09:27 AM
Bburr's Avatar
Bburr
I only have one steering wheel.
Old Nov 18, 2021 | 10:40 AM
Zymurgy's Avatar
Zymurgy
Moderator
What is the Checkmark enclosed in a circle? which can be found in the FAQ section of the sticky thread Manuals, Reference Material, FAQs, DIY Threads.
Old Nov 18, 2021 | 12:18 PM
CP's Avatar
CP
If you look closely, you will see that it is NOT a check mark. It is "<".
Old Nov 18, 2021 | 12:23 PM
jcp911s's Avatar
jcp911s
Simple... you just need a Bigger DIC
Old Nov 18, 2021 | 12:57 PM
THX_ZORA's Avatar
THX_ZORA
yea! that caught me a couple of times when I was wanting to save a location for front lift. I hit the "enter" key of the thumbwheel, as that is acknowledgement to take a action on everything else I had encountered.......but not for front lift. I suppose since it is using a memory location, they wanted to make it a different acknowledgement...
Old Nov 18, 2021 | 01:25 PM
godzilladude
I don't know why they wouldn't just say "click the wheel", but whatever. Thanks!
Old Jan 5, 2024 | 08:23 PM
Bluehinder's Avatar
Bluehinder
No offense, but you shouldn't even buy the car if you're worried about that many things. You're just setting yourself up for disappointment.
Old Jan 5, 2024 | 10:40 PM
blackvetterzo6's Avatar
blackvetterzo6
Thanks.
push in right thumb nail on steering wheel
Old Jan 5, 2024 | 11:12 PM
Kracka's Avatar
Kracka
Dick swinging contest around here at times. Like you said, just press down in the scroll wheel.
Old Jan 6, 2024 | 12:01 AM
Kwagnerhvac's Avatar
Kwagnerhvac
That was very helpful.
To The Check Mark
Old Jan 6, 2024 | 12:27 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Except if you look closely at the prompt, it doesn't say to use the check mark to save a location. It clearly shows a left arrow to save, enter to dismiss.
Old Jan 6, 2024 | 07:52 AM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
The steering wheel has a thumb ?
Old Jan 6, 2024 | 01:39 PM
trumanjd1's Avatar
trumanjd1
Thats not a nice thing to say about Richard!
