Sponsored by: Wheel Design
Difficult to Clean Radiator Guards
Old Nov 21, 2021 | 10:13 AM
KentCNC's Avatar
KentCNC
Default Difficult to Clean Radiator Guards
For those that have radiator guards that are mounted behind the grills, are they difficult to clean? I can imagine the bugs and leaves could be difficult to clean but not sure I like the guards that are mounted in front of the grills.
I am not interested in the guard/no-guard debate. There are many threads on that topic.
Old Nov 21, 2021 | 10:56 AM
MMD's Avatar
MMD
Can't tell you for certain as I do not have my C8 until next week. However, I originally thought the same as you. I now think it shouldn't be that difficult to clean the screens using a blast or 2 of a pressure washer.
Old Nov 21, 2021 | 11:03 AM
Grey's Avatar
Grey
Trick that will help you. Pull them out clean them and then give each grill a couple coats ceramic <both sides> . Let dry, then reinstall. That will make your future cleaning much easier. Bugs will stick less and those that do, will wipe off easier. Good luck
Old Nov 21, 2021 | 11:12 AM
John58's Avatar
John58
Veteran: Marine Corps
That's not so easy to do! Just go and get a spray bug and tar remover, clean them off then apply a coating of only those spray sealants.
stevenmk's Avatar
stevenmk
This has not been an issue for me because I had the bug screens ceramic coated with the rest of the car. Bugs easily wipe off with a soft moistened washcloth. Not sure if a high pressure washer could bend radiator fins?
Old Nov 21, 2021 | 11:27 AM
Spamburger_Hamburger's Avatar
No trouble keeping mine clean. Rare something is stuck in there enough to need extra attention.
Old Nov 21, 2021 | 11:38 AM
MMD's Avatar
MMD
Not possible. Plastic will not permanently bend. Aluminum grills I have are too stout. Still believe power washer is the way to go. Few blasts and everything is good again. No need to ceramic coat
Old Nov 21, 2021 | 01:23 PM
EasyElliott's Avatar
EasyElliott
I decided before the purchase of my 2021 C-8 not to install grill guards. But on the 1,400 mile trip home from picking up my car, I ran into more bugs that I could believe. The damage to the condensers that had occurred took me many hours to straighten the bent fins, using a plastic tool. I was concerned that I could damage the condensers using my pressure washer, but the bugs were imbedded in the fins and I had to blast them out with my pressure washer. Got the condensers looking like new and installed grill guards.
On a separate note, I was concerned where all the debris would go, but it all drains out. No change in coolant temperature since the install. Now if guards get dirty, I just pressure wash.
Old Nov 21, 2021 | 01:28 PM
Phil1098's Avatar
Phil1098
I just use a garden hose and have zero issues cleaning them. I do occasionally use some forceps to pull out the big ones (grasshoppers with landing lights).
Old Nov 21, 2021 | 02:46 PM
avigar's Avatar
avigar
I read that some have used metal dental pics to get into crevices behind the screens. I plan to try this out once I get my C8 and screens installed.
Old Nov 21, 2021 | 02:57 PM
NextOne's Avatar
NextOne
After nearly 7,000 miles, pretty much the same for me. But I have found some bug parts remaining, but got them out either with a detailing brush or my air compressor.
I've used these to straighten a few bent fins. When installing the screens, be sure to place some cardboard in front of them to protect them and your knuckles.
I would not point a powerwasher nozzle near the fins.
Old Nov 21, 2021 | 03:20 PM
MMD's Avatar
MMD
Could use a dental "Water Pik" These work great on teeth. Should work well on this application too but still a pressure washer would make quick work of dirty grills.
Old Nov 22, 2021 | 07:26 AM
Rapid Z's Avatar
Rapid Z
Pressure washer at a do it yourself car wash.
Old Nov 22, 2021 | 09:15 AM
sanman55's Avatar
sanman55
I know that chevy does not know everything but they spent a lot of time on this baby..Temp. was a major factor on the engine.Now I know you car read anything on the net but I think if it was a problem gm would have addressed it..JUST my opinion...I am leaving mine off that I ordered..
Happy thanksgiving to all..Stay safe
Old Nov 22, 2021 | 11:49 AM
Rapid Z's Avatar
Rapid Z
I just sent my screens to my out of town dealer for them to install during the prep.
Old Jan 18, 2023 | 05:04 PM
bob67327's Avatar
bob67327
Cruising
Default Debating alternatives...
We put grill guards on our C8 and bugs / small stones still got through to the condenser fins. I can see bugs, and some fins are bent.
We’re considering a stretch-bra (mask). That would certainly stop things, including considerable air flow.
We’re also considering some semi-rigid black plastic screens (trimmed to fit; 3 on each side) that I’d put in front of everything. I’ve ordered some designed for home fish tanks. They’re said to have 7 holes per inch, so mosquito size insects could still get through.
I know from our C7 experience that cleaning these things requires dental-like tools, and is time consuming. I never used a pressure washer because it seemed risky. Am I too cautious?
BTW, has anyone had success pushing bugs out by hosing the radiator from the back? From inside the front wheel-well? Just looking it seems that wouldn’t work (?).
Another question: how can we know when the radiator electric fans come on? When highway cruising at “ordinary” temperatures I’d not want them on (unless the AC compressor was also on). If using the stretch-bra caused the fans to run nearly all the time I’d not want to use it. Would monitoring the coolant temperature provide a reliable way to know if the fans were on?
Good luck to all of us trying to protect those vulnerable parts! bob
To Difficult to Clean Radiator Guards
