Sponsored by: Wheel Design
suspension choice
Old Nov 22, 2021 | 04:58 PM
mmmc8's Avatar
mmmc8
Default suspension choice
New to GM and corvette so I have a question to the forum experts:
Since c8 is not AWD what suspension combination will deliver optimum stability in every day driving?
is z51 PLUS magnetic ride is the best for controlled driving ?
Also, if car doens't have z51 package it means no rear differential of any type?
Again, this is not for track driving but to have most controlled drive in any situation.
Thanks!
Old Nov 22, 2021 | 06:22 PM
RKCRLR's Avatar
RKCRLR
Here we go again....
The best "control" would be from a Z51 with MSRC (FE4 suspension). How much better is a debate.
A base with MSRC would be close.
A Z51 will have a tighter feel because of the increased spring rates.
But all C8s are very good on the road, it's not like any of them are uncontrolled.
The base has a mechanical limited slip differential, the Z51 has an electronic limited differential. If you add MSRC to a Z51 then you also get PTM (Performance Traction Management) but that mostly a benefit on the track.
The best value for spirited driving in the curves is probably a base with MSRC.
Old Nov 22, 2021 | 06:35 PM
Avanti's Avatar
Avanti
"...what suspension combination will deliver optimum stability in every day driving" Have you always driven 4-wheel drive vehicles? Come on, the C8 is a modern sports car, any suspension that comes on it is superior to most other vehicles, no matter how you define "optimum stability," as long as you mean on the street.
As for me I always get the simplest sports car suspensions available, no leaky shocks, glitched computer system, etc. Since I keep everything indefinitely, this approach has never disappointed. All the best, no matter what you choose.
Old Nov 22, 2021 | 07:16 PM
mmmc8's Avatar
mmmc8
Yes, had AWD for the last 20+years, My current DD is E63s wagon AWD and it is impossible to lose traction in that tank.
Old Nov 22, 2021 | 07:20 PM
jcp911s's Avatar
jcp911s
I have driven my C7 with Z51 and MSRC, on the track, and can tell you the system is excellent... however. you need to spring for wheels, and a set of Hoosiers...
I just bought a Cayman S with a 3.6 conversion... spent $6K on custom-valved Ohlins Coilovers, and can tell you the Ohlins shocks are outstanding, but the MSRC on my 2016 C7 Is superior...
You have the choice to **** all your money away on BS after-market equipment, but give the Professional Engineers at GM a little credit... they do know what they are doing...
Old Nov 22, 2021 | 10:42 PM
Red Mist Rulz's Avatar
Red Mist Rulz
The non MSRC shocks are oil filled just like the MSRC ones. What makes you think only the MSRC shocks can leak? For that matter, what makes you think the recent generations of them have a leak problem. I know dozens of C7 owners with MSRC and not one of them has had a leak. Nor have they had any "glitched computer systems." It's not 1995 any more.
Old Nov 22, 2021 | 10:54 PM
Big Lebowski's Avatar
Big Lebowski
Thanks!
To answer your question, I’d say Z51 with Magnetic Ride Control. It is incredible and I’ve never had any “leaky” MRC issues and I’ve owned C6’s, C7’s and now a ‘22 Z51 HTC with MRC and no problems…just miles of smiles,
Old Nov 23, 2021 | 08:38 AM
mmmc8's Avatar
mmmc8
Thanks all! Will go with z51 + MRC.
Old Nov 23, 2021 | 10:02 AM
RKCRLR's Avatar
RKCRLR
Since nobody's mentioned the downsides of the Z51 I'll do that just to make sure you are aware of them (I'm a fan of the Z51 + MSRC).
1) Brake dust - There are aftermarket brake pads to address this.
2) Summer Tires - They suck in the snow and ice and have diminished traction in cold, wet conditions vs the all-season tires on the base. This may not be a problem depending on where you live.
Old Nov 23, 2021 | 10:08 AM
Salmon057's Avatar
Salmon057
MSRC is one of the best options and the price has not increased like many other options.
Old Nov 23, 2021 | 11:35 AM
Fast Dawg's Avatar
Fast Dawg
My C6 and C7 both had the Z51 package and they both rode much stiffer than my non-Z51 C8. I used the Z51 money to buy MSRC, performance exhaust, and the front lift. My C8 sticks to the road much better than either of my Z51 equipped C6 and C7 during spirited driving on curvy roads.
Old Nov 23, 2021 | 12:01 PM
WalterSobchak's Avatar
WalterSobchak
I think you will be very happy with this set up.
Old Nov 23, 2021 | 12:17 PM
Salmon057's Avatar
Salmon057
MSRC get it now, can't add it later.
To suspension choice
