Sponsored by: Wheel Design
Lowered…finally
Old Nov 24, 2021 | 05:20 PM
Dashracing's Avatar
Dashracing
Active Streak: 90 Days
Default Lowered…finally
I was hesitant to lower my C8…worried about things like compromised ride, wheel/tire clearance and the horror stories about C8’s falling off the lift. I finally did it though and none of the concerns materialized. Ride is either the same….or maybe even better and even though I have wider and more aggressive offset wheels, there are zero issues with clearance. The apprehension about putting the car on the lift was unfounded as well. Using the pucks in the proper locations gave the car a very balanced feel on the lift. Even though, I still removed the rear wheels first. It’s not slammed but is lowered exactly the right amount for me.
Popular Reply
Nov 24, 2021, 08:43 PM
Synergy-'s Avatar
Synergy-
Looks great! Lowered C8 really changes the look! I also dropped it down using Z51 coilovers but decided I wanted to go a little lower so I added the Paragon Performance springs as well.
Old Nov 24, 2021 | 06:45 PM
Kracka's Avatar
Kracka
Lowered with the stock adjustment? All the way down?
Old Nov 24, 2021 | 06:54 PM
Dashracing's Avatar
Dashracing
exactly, stock coil overs lowered about 90%. Left enough threads on the adjuster ring to feel comfortable with it.
Old Nov 24, 2021 | 07:22 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looks great, question my mechanic has similar lift, do you have the pucks.
Old Nov 24, 2021 | 07:40 PM
Dashracing's Avatar
Dashracing
yes, and same pucks fit my C7 and my C5. Just standard aluminum pucks. Nothing fancy.
Old Nov 24, 2021 | 07:49 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
‘Thank you going to order me a set, we take delivery on Friday.
Old Nov 24, 2021 | 08:03 PM
jkwonza's Avatar
jkwonza
That’s what I like to hear - I will be having mine lowered on the stock shocks as well, a little bit apprehensive as well, but posts like this are great to see
Old Nov 24, 2021 | 08:25 PM
Dashracing's Avatar
Dashracing
was hoping someone could relate and also benefit from my experience. Thanks for the reply !!
Old Nov 24, 2021 | 08:39 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
CL
Old Nov 24, 2021 | 08:43 PM
Synergy-'s Avatar
Synergy-
Old Nov 24, 2021 | 09:23 PM
Dashracing's Avatar
Dashracing
that looks good !! Do you have wheel spacers ?
Old Nov 24, 2021 | 10:20 PM
Kracka's Avatar
Kracka
Wow guys, both look excellent! I think lowering mine down will be my next DIY project.
Old Nov 24, 2021 | 10:28 PM
Kracka's Avatar
Kracka
​​​​​​Are your perches fully lowered with the springs? The fender gap looks perfect.
Old Nov 24, 2021 | 10:54 PM
Dashracing's Avatar
Dashracing
Old Nov 24, 2021 | 11:09 PM
oldC5's Avatar
oldC5
Side pic would be better.
Old Nov 24, 2021 | 11:26 PM
Dashracing's Avatar
Dashracing
agree. This was on the way home and grabbed a quick pick to catch the sky colors. Next time I get the car out I’ll try to get a decent side photo….even though I think the car looks kind of plain from the side.
Old Nov 25, 2021 | 06:48 AM
landsteam's Avatar
landsteam
Does the front splitter lower the ground clearance or it just sticks out further than the stock Z51 splitter?
To Lowered…finally
Old Nov 25, 2021 | 06:53 AM
Greg00Coupe's Avatar
Greg00Coupe
So the lowering process is the same as prior models? If so that was fairly simple
edit…..I found the diy stickie
Old Nov 25, 2021 | 08:08 AM
Dashracing's Avatar
Dashracing
i don’t think it’s any lower.
Dashracing's Avatar
Dashracing
differrnt process, but still simple.
