There were numbers published on this site quite some time ago, but it turned out that was the shipping weight from a GM part vendor, so probably heavier than what the wheels actually weigh. The OP of that said "packing would only be a couple of pounds, but I just shipped some wheels and I believe it was a good bit more than that.
19x8.5" +52mm F 25.69lb 20x11" +64mm R 32.11lb 5x120mm bolt pattern 14x1.5mm lugs 66.9mm hub bore
