Sponsored by: Wheel Design
Installed extended Splash Guards today
Old Dec 26, 2021 | 03:02 PM
johnodrake's Avatar
johnodrake
Moderator
Default Installed extended Splash Guards today
Acquired on eBay. Good quality. Good fit. Easy install.
Caution: The right rear 7mm screw was installed really tight and the head broke off when I tried to loosen. A real bitch to get off after that.
Old Dec 26, 2021 | 03:32 PM
LANZ06's Avatar
LANZ06
Could you take a pic from the front and back of the car so we can see how far they stick out? Thanks
Old Dec 26, 2021 | 04:07 PM
Good job, John. Every little bit of protection helps.
Old Dec 26, 2021 | 06:39 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I also like to from back to front, to see how they fit and stick out!
Old Dec 26, 2021 | 07:05 PM
Rapid Z's Avatar
Rapid Z
Your Welcome 😀. That’s strange because all of my bolts were loose.
Old Dec 26, 2021 | 08:04 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice
Old Dec 26, 2021 | 08:32 PM
johnodrake's Avatar
johnodrake
Moderator
It was so tight the OEM guard was distorted where the washer was.
Old Dec 27, 2021 | 03:06 AM
Rapid Z's Avatar
Rapid Z
no pics of the rear but here is the front.
Old Dec 27, 2021 | 02:48 PM
johnodrake's Avatar
johnodrake
Moderator
Old Dec 27, 2021 | 05:33 PM
SoCal C8's Avatar
SoCal C8
Livin the Life
2024 C8 of the Year Winner - Modified
I went with the XLs as the HRE’s are flush with the fenders. These are Carbon Flash from Extreme Online and were $249 for a full set (front and back). I purchased them back in February after I found my C8…..seems they have upped the price a bit since then.
Old Dec 28, 2021 | 08:36 AM
6667vette's Avatar
6667vette
Old Dec 31, 2021 | 11:13 AM
johnodrake's Avatar
johnodrake
Moderator
I put the correct 7mm screw in the right rear. Dang screw cost 7 bucks at the dealer parts shop.
Old Dec 31, 2021 | 11:19 AM
gchu's Avatar
gchu
I put mine on last night - took about 30 minutes... The tough part was when I removed the originals from the car, almost all the clips stayed on the car
I used a small set of forceps to pull/pry them out
Old Dec 31, 2021 | 11:58 AM
Rapid Z's Avatar
Rapid Z
Same thing happened to me it was like they were glued in in fact I cracked one of the sots in the front fender getting one of them out. The plastic pry tool was almost useless.
When I swapped them on my 2020 they were much easier to remove. As for those huge wide ones above I'm not sure I like the look.
Old Dec 31, 2021 | 01:22 PM
New2me's Avatar
New2me
2023 Corvette of the Year Finalist - Unmodified
2022 C8 of the Year Winner - Unmodified
Can someone educate me about why I need splash guards or XL splash guards?
I live in NE and never had splash guards on any of my cars….1966 on. I have never had any issue. However, I have never owned a Corvette. Is it because it is so low and what am I protecting against?
Old Dec 31, 2021 | 01:28 PM
1FSTZ06's Avatar
1FSTZ06
They never required but the tires on the C8 do extend beyond the lower body lines so you're going to get a lot of debris hitting the lower panels. It's really cheap insurance to reduce that paint damage and they don't look bad on the C8.
Old Dec 31, 2021 | 01:45 PM
RKCRLR's Avatar
RKCRLR
I'm satisfied with the protection the OEM splash guards provide. The XL splash guards will provide more protection but I prefer the more inconspicuous look of the OEM guards.
To Installed extended Splash Guards today
Old Dec 31, 2021 | 08:12 PM
Blindfingers's Avatar
Blindfingers
I saw from one GM supplier that the splash guards may be in stock at the end of January so I've been checking out the ones on the Bay.
There are about 5 or so selling, from China, and in the same price range of about $120. It's tempting especially since the OP said the quality was good.
Hmmm... decisions??
Old Dec 31, 2021 | 08:18 PM
Jeffthunbird's Avatar
Jeffthunbird
I used ACS. Same as GM. Easy but a few clips had to be pulled, straightened and reused. I think they are needed to keep the paint from being sand blasted.
Old Dec 31, 2021 | 08:40 PM
C21ban's Avatar
C21ban
2022 C8 of the Year Finalist - Unmodified
These are close-ups so they seem a little more pronounced (especially on the front) but as you can see in the last pic, they are hardly noticeable unless you are really looking hard.
ACS btw and a little longer tail on the bottom helping to keep rocks from throwing out against the paint so I feel they are certainly warranted regardless of the brand.
Front with wheel slightly turned
Looking back on rear
Rear
