Sponsored by: Wheel Design
Shock Tower covers
Old Dec 29, 2021 | 01:44 PM
Buzzsaw1234's Avatar
Buzzsaw1234
Default Shock Tower covers
I remember when this was a huge freak-out among new C8 buyers. Water in the shock towers. Now there are many covers available.
Ya'll think these are necessary or just something else to spend money on?
I see the new GM approved Grill Screens by Scrape Armor. They look good but there is another $400+installation.
I'm about to write a VERY large check (for me). Am I buying a "Money Pit"?
Popular Reply
Dec 30, 2021, 11:13 AM
LJT's Avatar
LJT
easy way
Old Dec 29, 2021 | 01:52 PM
Zymurgy's Avatar
Zymurgy
Moderator
Just something else to spend money on - shock tower covers and grill screens.
Old Dec 29, 2021 | 01:53 PM
C21ban's Avatar
C21ban
2022 C8 of the Year Finalist - Unmodified
To me, worth the cost.
Old Dec 29, 2021 | 01:55 PM
Rapid Z's Avatar
Rapid Z
I purchased the cheap Chinese after market ones I think they are worth the $35 otherwise they get full of soap after washing.
Old Dec 29, 2021 | 01:56 PM
Phil1098's Avatar
Phil1098
It's as deep as you want to make it. I remember the signature of a member on the Mustang forum that said "I never planned to make a 10 second $100k Mustang, it just turned out that way"
Old Dec 29, 2021 | 01:58 PM
bullmarket's Avatar
bullmarket
POSSE SENIOR RIDER
I installed the shock tower covers on my 2022. Not so much to keep water out, but I thought it had a cleaner look to the area when the cover is off.
I did not install the grill screens as I do not like the look. I have not had a problem...yet.
'Money Pit'. Nope. You decide how much to spend on accessories/add-ons. Some are effective, most are for looks.
Old Dec 29, 2021 | 03:53 PM
dohabandit's Avatar
dohabandit
I figured I would just drive it past my 500 mi first stage breakin period and then decide then if I really needed the grill screens.
I didn't make it to 200mi. Looked down and to my horror, I had a lot more dented fins than I had expected and I make it a point to avoid being close to big trucks and other stone throwers as much as possible.
It's not the "radiator", it's the AC condenser that is getting hit, but regardless it looked horrible and it wasn't fun trying to comb those out. I had to pick at them with a variety of tools to straighten them.
I installed some CHEAP screens. They look fine, stop the damage to the condensers and I haven't seen ANY change in cooling performance here in Florida.
I had rusty bolts in my front strut towers due to water pooling there. My C8 was birthed on 5/20/21 with the "new" design that isn't supposed to have problems there. Still does, so I put covers on them.
Here is something to shock you also. If you have MSRC, there are some BOOTS that cover the top of the strut where the wire enters.
Pull those boots back. I bet you will find a ton of rust already if you haven't filled that boot with dielectric grease. Word to the wise! Why doesn't GM fill that boot with grease? It's a mystery to me.
Old Dec 29, 2021 | 03:56 PM
Buzzsaw1234
Lots of mysteries at GM on the C8. Thanks for the info
Old Dec 29, 2021 | 04:53 PM
Avanti's Avatar
Avanti
Your car, your money... your choice, of course. Just like any car, some find ways to keep "playing" with them while others just drive 'em.
Old Dec 29, 2021 | 05:20 PM
Greg00Coupe's Avatar
Greg00Coupe
I put them on my 20, made my own. Checked my 22 after a wash and they were bone dry. Not planning to check again, not that big a deal, but did install grill covers on both.
Old Dec 29, 2021 | 05:42 PM
Big Lebowski's Avatar
Big Lebowski
A discretionary money pit. It’s up to you how many floor mats, car covers, screen protectors, strut tower covers, t-shirts and trinkets you buy. None are “required”.
Old Dec 29, 2021 | 10:02 PM
It really is up to you how much you want to spend on the car - it can be just fine as it comes from the factory.
Old Dec 30, 2021 | 10:59 AM
papillion's Avatar
papillion
Default Grain of Salt
OCD owners drive the aftermarket doo-dad hysteria. Far too often, a solution looking for a problem to solve. GM knew you'd get water in the top of the shock towers. And didn't care. Nor do I.
Old Dec 30, 2021 | 11:08 AM
Kracka's Avatar
Kracka
I'm 99.9% certain any water that does find its way to the shock towers is from the intense water leak test performed on select cars at the factory. I've hand-washed and driven in plenty of heavy rain storms and mine have remained bone-dry from day #1.
Old Dec 30, 2021 | 11:13 AM
LJT's Avatar
LJT
easy way
Old Jan 2, 2022 | 02:24 PM
slayne154's Avatar
slayne154
After picking up my new 2022 C8, I checked the strut towers and found the driver's side tower (center bolt hole and surrounding holes) had about an inch of water. The passenger side was dry. I removed the water and installed the covers I found on Amazon- paid $40 and they went on in about 15 minutes. I'm not sure how long it would take for the water to evaporate but for me it's peace of mind.
Old Jan 3, 2022 | 03:27 PM
Blindfingers's Avatar
Blindfingers
The whole price rate is due to the Corvette tax. Vendors jack the prices umpteen percent on things that cost a few dollars to make and sell. Not rocket style designs.
To Shock Tower covers
Old Jan 3, 2022 | 06:20 PM
Majestic94's Avatar
Majestic94
GM didn’t know you’d get water in there, that’s why they attempted to fix it by plugging some holes in the cowl. It was a cheap fix but apparently doesn’t work.
As an engineer, I can tell you the aluminum shock tower with a steel bolt submerged in water is a perfect recipe for galvanic corrosion.
Old Jan 3, 2022 | 06:23 PM
Buzzsaw1234
Old May 11, 2022 | 08:05 AM
petsur's Avatar
petsur
I dried my shock towers after I bought the car and they had a lot.
1 year later, after washing the car about 5-6 times there is NO water in the shock towers. I used a pressure washer and spray it everywhere. The water is from Chevy's leak test at the plant.
