Transmission Update
For instance, there is a known issue with the seals on the rails that the shift forks ride on that cause misalignment if they aren't installed properly in the factory.
If they see a code related to that, then a flush isn't going to correct that issue.
This isn't related to the pan seal, this was specifically mentioned that it some how would be mis-aligned when the back end of the DCT was being assembled. I suppose a very slight misalignment could cause things to bind under certain circumstances.
So, just spitballing here, but maybe there is debris, or gunk (or a McDonalds wrapper), on the shift rods, or misalignment, or stiction, making it a bit harder to activate the shift forks, or rails, rods, whatever’s all in there. So when the battery may not be 100%, there is not enough “oomph” to activate the forks, rods, whatever. But after sitting on the charger, the battery has enough power to force the rods to move, and once moved, they stay unstuck, until the car sits, battery is less than ideal, and they get stuck again. It kinda’ makes sense, since the times I lost the odd gears, If I drove a few miles, I would get all the gears. So maybe the car charged the battery enough to move the forks. And once moved, worked properly. Or it is temperature related and once a certain degree was reached, it once again shifted properly. But I’m leaning on the theory that there is gunk (debris) on the forks, and it takes all the batterie’s power to get it moving. But, what the hell do I know?
So the solenoids are activated by electrical current? Then the solenoids move the hydraulic fluid to work the transmission?
Inquiring minds need to know. Thanks in advance.
It's probably these rods in the solenoids that are sticking due to debris.
