Transmission Update?
In my town I know of at least 2 others that had transmissions replaced.
Could the problem be getting worse?
These post are from just one group I'm on.
It seems that the cars which have the serious problems are acknowledged early in ownership, like in the first 500-1,000 miles. Just my observation.
I watched the Tech perform the flush. Took about 10 minutes with his PC connected to my car via the OBD port and GM's service computer via WiFi. The GM program conducted the Flush. We watched. His screen showed what was being done as valves etc cycled with the engine running. The procedure said it was to dislodge and debris which it directed to the filter BEFORE it was removed. Appears to me the initial wear of the multiplate clutch plates, metallic parts from gears, shift forks, synchro cones etc wearing in can cause blocking of valves and passages.
Larger diameter out clutch disks get to wear in faster slipping slightly when stopped.
The next day my vehicle had a "shudder" in 1st, 2nd, and 3rd gear. It felt really jerky, like the vehicle was surging. It went away as the vehicle was driven / warmed up. No codes on the OBD2, but my misfires #'s are up.
My guess is that I got shitty gas from that highway station. I am considering dumping some octane booster in the tank, maybe they sold me premium gas but were pumping 87?
That brings up the question, does anyone know if there is a recommended octane booster / fuel treatment to use?
Lucas, VP, STP, K100, 104+, RoyalPurple, Boostane, Techron, Rislone, RaceGas, Klotz, ????
The best course of action is probably to top off with the highest octane you can find.
Before using an additive find a hot rod shop or drag racer as they will usually sell you race gas that is 100+ octane. Can go to a small airport that is for private plains etc and get similar!
The light went out and it is shifting normally but now I am fearing I might be in that 1%.
