..... Doesn’t look too complicated, but is removing the existing cover and replacing it with a colored cover a difficult job?
Originally Posted by JerryU
Yep, looks easy. Several video's. Two show it's not so easy and the foolish folks trying, made errors. One mangled the front fitting that holds a hose by trying to remove old one while still on OEM. After several tried they managed it so bad it didn't fit the new cover! Also, wherever they bought the new colored cover it did not have what they called heat insulation like the OEM. It's there for sound deadening NOT HEAT!
As Usual, "My How To" Many Pics with Captions PDF's Show the Tricks and What NOT To Do! Hard to Screw up BUT Some Do!
Enjoy: http://netwelding.com/Engine_Cover.pdf
Originally Posted by JapanC8
There are a handful of videos on YouTube, just search for corvette c8 engine cover
Originally Posted by C21ban
Very simple to do, even for us novices. Just be careful when moving bol;ts so you don’t drop them in the engine bay.
Yep, one of the CAUTIONS in my "How To Install" PDF states: "Loosen the four 10 mm bolts holding the engine cover in place. Note they are not very tight, relatively low torque required. That is what should be used when reinstalling! Only use a wrench to loosen each bolt a few threads. Then use you hand to remove it completely and put it in a safe place. YOU DON’T WANT TO DROP A BOLT!” I dropped a screwdriver and it did NOT fall on the ground! But was easy to retrieve. A bolt might not be so easy! "
Originally Posted by ElSyd
C21ban - Now you tell me! Did mine a weekend ago and one of my screws went in to the abyss!
Funny. I wondered IF I would make a How To Video, it's SOOO simple. Then like most I looked at several video's. The jokers screwed up a simple job (see my post quoted here.) Also most VIDEOs don't take the time to say WHET NOT TO DO! My ODF's do, like the one I made. It clearly said "loosen the bolts" with a wrench then remove each by hand! Yep drop a bolt can make for a long day! Now have ~60 PDF How To's for DIYers like myself. Cautions are more important then what to do in many cases, always include in my Text/Pic PDF's
