Sponsored by: Wheel Design
Wheel vibration
Old Mar 2, 2022 | 10:18 AM
Ryan Ol Ghanta's Avatar
Ryan Ol Ghanta
Default Wheel vibration
So I bought wheels for my C8 @WHEEL DESIGNERS (Stance) in December
Had a mobile wheel installer balance/mount them
They've come out three times now to balance and we cannot seem to get a proper balance
I feel a vibration SOMETIMES on the car and it is subtle
- goes away if I stiffen the suspension, and yesterday it went away after I filled up gas
I now am scheduled for next week for a "road force" balancing. I used to daily drive and now have barely put on 300 miles since December because of this new issue.
Is there a chance they could be out of round from the factory?
Old Mar 2, 2022 | 10:33 AM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
It's possible, but unlikely.
Let us know what you find.
Old Mar 2, 2022 | 10:55 AM
Kracka's Avatar
Kracka
They'll be able to tell you what the issue is, if any, when they get the wheel/tire on a good balance machine.
Old Mar 2, 2022 | 04:12 PM
Avanti's Avatar
Avanti
In the "old days" we would deflate the tire and turn 180-degrees on the wheel and try again. Often worked. Have the "balanced" okay as has been done to date? Yes, get it to a real tire shop, ASAP.
You reusing your original tires? A faulty wheel is possible but not likely, but I don't know what type of manufactured wheel you got. All the best!
Old Mar 2, 2022 | 05:34 PM
Zormecteon's Avatar
Zormecteon
A "trick" a good tire and wheel man will use is to spin, then mark where a weight is indicated, let the air out of the tire, then spin the tire so that that point is where the valve stem is, then spin again.
Many times there this will eliminate the need for weight at that point. .. Another thing is that where the sticky weight is applied not just in the proper place in the diameter, "east-west" so to speak on the rim.
Good luck.
Old Mar 2, 2022 | 05:40 PM
Phil1098's Avatar
Phil1098
The newer machines that do a road force balance will show the technician where to move the tire on the rim for the best chance of lowering it.
Old Mar 2, 2022 | 05:41 PM
LT2/3LT's Avatar
LT2/3LT
Unmodified C8 of the Year 2021 Winner
Tires need removed to check the wheels. A good wheel guy will find your issue....if related to the wheel!
Old Mar 2, 2022 | 05:55 PM
steve8's Avatar
steve8
I've had wheels/tires mounted in the field several times.
For my backhoe!
Would never trust that for any car.
Get it to a real shop.
Could be the wheel.
Good luck.
Old Mar 2, 2022 | 06:46 PM
GTUnit's Avatar
GTUnit
Take the tire off and spin the wheel by itself on the balancer and watch for runout.
Maybe its bent.
To Wheel vibration
