C8, 2020
Unless this is your first car EVER, lol, when brakes squeak, that's an indicator that they might need to be replaced.
The solution is take the wheel(s) off and inspect the brakes to see if they need to be replaced.
I'm not trying to be a total ***, but if someone ask a question like this, it's car maintenance 101.
What’s probably more likely is the pads need more copper paste (see Post #2 above), or the brakes need to be bedded. Bedding is free and can be performed without going to the dealer, so I’d try that first. Here is a link describing the process -> https://www.autoanything.com/resourc...in-brake-pads/
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Order direct here 24 hours a day @ Chevrolet Brake Pads – Amp'd Autosport (ampdautosport.com) and use promo code z28 for your discount.
Front part Number CT28951F
Rear Part Number CT28951R
ALL COMPOUNDS ARE IN STOCK!
Carbotech brake pads are 100% Made in the USA!
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per
All major CC and Pay Pal accepted.
Check out Promo code:z28
The key with performance brakes is to use them aggressively at least occasionally!
This was my experience with my 2014 Z51. Broke the brakes in as suggested, modest brake pressure. At <1000 miles it was squealing like a stuck pig with light brake pressure. Check out "brake bedding" on google (GM for whatever reason calls in burnishing in the Owner's Manual ONLY for Z51 and ONLY for Tracking.)
But what happens is a very thin film of brake pad material forms on the rotor. It must form but also must be uniform! If spotty due to always using light brake pressure the skip/stick friction resulting causes vibration. That is likely what is causing the squealing.
I used 6 or 7 stops as GM calls for under Tracking (not the 25 they suggest!) That is hard braking (80% of max) and letting them cool for ~1/2 mile between then repeat. The dealer will not do that (safety issue as it is for you, need to find a place street driving when not at a Track!) If they did GM will not reimburse them! GM will pay for pulling the pads, applying brake pad lub to the sides and back. For many that only last a short time then back! You're putting a band-aid on the issue not eliminating the source.
I did it for my 2014 Z51 and no more squeal. AND I do use the brakes aggressively often which keeps that uniform pad material layer.
After 6 months I got feed up with the OEM pad dust. I installed Carbotech 1521 pads that don't require bedding! Never a peep in 3 years. Installed them on my 2017 Grand Sport and now my C8! Never a peep! BUT I do use the brakes aggressively periodically. The pads stop great and low dust. Wash my wheels only when I wash the car.
