Sponsored by: Wheel Design
Quick question on OTA software updates
Old May 13, 2024 | 11:17 AM
SMOKN C8's Avatar
SMOKN C8
Originally Posted by tadda
I'm fairly certain that OTA updates were discontinued late last Sept due to chronic problems with hangups and failures draining batteries and resulting in some C8s having to be towed to Dealerships to resolve system problems created by some of these OTA updates...
The last update that caused problems for many was GM N23-2418150 (9/26/2023)....
I'd be interested to hear if anyone has received an update after Sept '23?
GM N23-2418150 failed on my C8 (first and only failure). My last successful update was GM N23-2407890 on 09/25/2023
Old May 13, 2024 | 11:30 AM
undecided1965's Avatar
undecided1965
My car used to nag me for updates. I never did them. It has not nagged me for at least 6 months.
Old May 13, 2024 | 11:31 AM
papillion's Avatar
papillion
Default Rip
I missed that GM had permanently suspended OTA's. I did them all (4) without issue. But felt the same anxiety when I started each one. And elation, when I revisited the garage to find the OTA process had come and gone.
Old May 13, 2024 | 11:37 AM
Bob Paris's Avatar
Bob Paris
Originally Posted by gdb069
Wow, too much incorrect information or maybe a little confusion:
1. There are 2 processes that happen with OTA a) the files are downloaded with the car operating ie driving around. There is no info or notic that the download is happening. Downloads can be interrupted (you stop the car) but it doesn't matter as the download will complete at some time.
2. Once the download has been completed there are certain conditions that must be met for the upgrade (Install) to happen including checking the batter state so Charge (SOC) based on ambient temp etc.
3. For the upgrade to happen the car must be parked so don't worry about driving. If the upgrade started and you start the car. the upgrade is backed out.
4. Most upgrades take about 15 minutes. My C8 takes about 5 minutes. But you can just park, accept the upgrade and leave the car.
5. You should not need a tender unless your battery is failing.
Originally Posted by AzDave47
..and all those people that have had the C8 OTA hang up, not finish and have the dead battery are liars in your opinion. Next one that posts, you should tell them that.
GDB069's experience with OTA updates mimics mine. For my '22 Z51 HTC I have received notification of 4 or 5 updates. Followed the simple instructions while home or away and the update took about 5 minutes. No issues and I am happy and confident with the process.
Old May 13, 2024 | 12:01 PM
tadda's Avatar
tadda
Veteran: Marine Corps
That last update (GM N23-2418150) late Sept of '23 was an issue for many which caused GM to stop / pause future OTA updates ....Mine did go through and was the last of the 4 updates I did receive....
