Hard to say without doing FA to determine root cause of the failure. If the operating hours have exceeded the infant mortality phase of the failure (bathtub) curve then it could be argued that the remaining lifters would be less likely to fail than a new set.
Thanks here is another question? I had two issues the number 5 lifter in bank 1 and the issue with the car at idle when idol at a red light the rpm would occasional drop below 1,000 as if was losing power struggling to breathe maybe a slight mis fire not sure but the rpm dropped and I would feel a slight vibration so would you think Maybe that changing all lifters would have been better or still hard to say Especially Since they have a known lifter issue just asking. and the tech states the lifter fixed my hesitation issue when going from V4 to V8 but I still have a slight vibration when idol not as much as before but still there
A LT2 idles at well less than 1,000 rpm if it is 100% healthy and normal. Lifters aren't built in sets, it's just one after the next, the rest my be fine for the life of the car.
Hard to say if that was a symptom of #5 leading up to the ultimate failure. I imagine you’re worried about putting it back together just to find out there is still a problem….Valid concern but I think you have to address the known failure first unless you have a reason to suspect other components, like FA results which would implicate a lot/batch of common components.
I would be surprised if you actually have a choice as to how many lifters are changed out. Chevrolet, more than likely, will only cover the damaged lifter. As has been mentioned, they are not built in sets so possibly no need to change them, however, lifter 5 is one of the four cyclinders that are deactiveated during AFM operation. I wonder if the AFM operation had anything to do with your failure. Perhaps you could lobby for them to at least change out the lifters in cyclinders 2, 3, 5 & 8, which are subject to AFM shutdown, as a precaution. I doubt they will go for that but at least there is a colorable argument there for the replacement as opposed to the replacement of all or even an entire bank. I always use Z Mode and never, other than for one brief experimental time period, allow AFM to be activated in my car. I realize it is seamless, other than a slight hiss when it shifts in, but I just don't trust it and I like the car much more in Z Mode anyway so I don't feel like I'm missing anything by not utilizing AFM. The nominal fuel savings doesn't mean a lot to me. I had a ton of problems with it in a Chevy truck years ago. One bitten, twice shy!
do you think it’s normal for the rpm to drop when idol at 1k and hesitate when the car is idle it seems to be an issue I have several friends and none of there C8’s have this issue the tech said it’s normal but if it was why then I don’t see it on any threads and the guys I ride with none have this issue just seems to be something wrong I do know that they C8 can idol at 500 but I don’t know if anyone that say it idols at 1,000 then drops to 9 8 or 700 and comes back up to 1000 creating a distinct hesitation and vibration - would you think that is normal or should I keep searching for a resolution
do you think it’s normal for the rpm to drop when idol at 1k and hesitate when the car is idol it seems to be an issue I have several friends and none of there C8’s have this issue the tech said it’s normal but if it was why then I don’t see it on any threads and the guys I ride with none have this issue just seems to be something wrong I do know that they C8 can idol at 500 but I don’t know if anyone that say it idols at 1,000 then drops to 9 8 or 700 and comes back up to 1000 creating a distinct hesitation and vibration - would you think that is normal or should I keep searching for a resolution
I think I know what you said (need some periods). Your RPMs shouldn't increase to 1000 at idle unless your engine is cold. Your idle speed should be steady around 650 RPM when warm although the LT2 doesn't idle silky smooth. But you shouldn't be able to see the RPMs varying significantly on the tach.
I didn't say that at all and you're assuming I did. What I said was, and is accurate, is a healthy LT2 idles while stopped at well below 1,000 rpm (steady at around 650 rpm). It shouldn't fluctuate all over and it certainly shouldn't hesitate. If your idle speeding is going up and down and there is vibration and hesitation something is clearly wrong.
yeah i guest the million dollar questions now is what? Hopefully I will get the right tech to figure it out. I appreciate the input I will post a resolution once I get a tech whom figures it out - this forum is awesome thanks again let me know if you have any thoughts on what it may be
It would be interesting to ask them why they belive the lifter failed and whether the failure was related in amy way to the mechanism that shuts the lifter down when the AFM kicks in. Please let us know what you find out. Good luck!!
I had a lifter failure in my 2021 C8 just before reaching 2000 miles. GM replaced all the lifters in Bank 1 under warranty (and the coil packs). I'm now at 9000 miles with no additional problems . . . fingers crossed. For what its worth, the technical service bulletin related to my repair (19-NA-218) appeared to recommend replacing all the lifters in the bank with the failed lifter.
Reason: additional information
So I hit my 2022 C8 back today so far pretty good we changed all the lifters in Bank 1 and the hesitation from V4 to V8 is gone and there is no hesitation when idle looks good feels good 😎
Oh wow just be patient my lifters took 3 weeks to repair but I would wait 6 to get it done right so I finally got it back and issue is fixed under warranty so all good for now
