Sponsored by: Wheel Design
Defective bolt?
Old Apr 3, 2022 | 01:56 PM
okaythen's Avatar
okaythen
Default Defective bolt?
This bolt near the oil dipstick got something on top of it, is it a defective bolt? The other ones seem fine.
Couple questions:
For my hydraulic engine bay hood it doesn't go up by itself when you push it up lightly like in C7, the hood you can pretty much set it at any position and it won't go up like regular hydraulic hoods. Is that how yours works too?
I was wiping off some water spots under the hood window, and a piece of paper towel fell off into the engine bay, I tried hard to find it but can't find it anywhere, it's about 1 inch by half inch. Should I try to find it will it cause a fire or it's no problem?
Old Apr 3, 2022 | 02:06 PM
Space Truckin's Avatar
Space Truckin
The bolt you reference looks/ seems to have some kind of "gunk" dropped on it, get a pick and clean it up....jm2c
Old Apr 3, 2022 | 03:33 PM
yelocarbuff's Avatar
yelocarbuff
Purple bubblegum the line worker had nowhere to dispose of.
Old Apr 3, 2022 | 03:38 PM
Kracka's Avatar
Kracka
No reason to worry about the paper towel; plenty of airflow through the engine bay at speed and it'll likely come out eventually.
Looks like a glob of adhesive on that bolt; pick it off if it bothers you. You may need to scrape or chisel it off.
Your hatch struts are fine and working as intended. The C8 hatch is much heavier than the C7 hood.
Old Apr 3, 2022 | 04:42 PM
JDSC8VETTE's Avatar
JDSC8VETTE
Lemon law?
Old Apr 3, 2022 | 06:48 PM
Pisswilly's Avatar
Pisswilly
Grapefruit law?
Old Apr 3, 2022 | 07:51 PM
ChiTownVetteTech's Avatar
ChiTownVetteTech
That’s the structural adhesive that the frame is glued together with. Almost impossible to remove. Have had many that we’ve delivered with some splatters and drips.
Old Apr 3, 2022 | 08:38 PM
Avanti's Avatar
Avanti
"Have had many that we’ve delivered with some splatters and drips" Fortunately, yours isn't where it readily shows!
Old Apr 3, 2022 | 09:36 PM
That sure looks like some adhesive.
To Defective bolt?
