Sponsored by: Wheel Design
c8 front trunk
Old Apr 14, 2022 | 04:58 AM
tigerlee's Avatar
tigerlee
Default c8 front trunk
just got c8 today, has only 200 miles on it but has a problem, cannot open the front trunk by key fob. I could open it by interior and front driver button.
Anyone has problem like that? Please give some an advice
Old Apr 14, 2022 | 05:17 AM
jimjimsC7's Avatar
jimjimsC7
Press button twice and hold on second press.
Old Apr 14, 2022 | 05:31 AM
tigerlee's Avatar
tigerlee
I did exactly what you said but not thing happen then I use second key fob to open it work, I wait for 5 min. and use first key fob try to open but it not work
Old Apr 14, 2022 | 06:48 AM
Dave Strickland's Avatar
Dave Strickland
I have the same issue. Mine is 3 days old. I’ve tried all with both remotes. Nothing.
Old Apr 14, 2022 | 07:42 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
My 2020 is 18 months old. Have the same issue. Trunk works fine with FOB, Frunk not so much!
I would say it appears to work about 10% of the time. I have tried all the "advice" re how long to push and wait between 2nd push. Tried both FOBs, gave up!
No big deal as easy to push button under driver's headlight and the one in the door. When I have groceries to put in the Frunk (if cold "stuff" don't put in trunk- gets hot) just as hard to get to a FOB as pressing button. When removing when I get home just press the door open button. Frankly same with Trunk, button works fine. My FOB never leaves my pocket!
Somethings just not worrying about!!!
My September 2 received 2020 was built the 1st week of the "Avoid Frunk hood coming open when driving software." In fact when I picked mine up from the dealer thought the new software would have to be installed as that is what GM said re timing. BUT turned out it came that way from BG. Has been the same from day 1. Worked at dealer and as I say 10% of the time I try with FOB.
Old Apr 14, 2022 | 07:51 AM
johnodrake's Avatar
johnodrake
Moderator
There may be an issue with the door lock receiver for the Frunk. Dealer should handle it
Old Apr 14, 2022 | 08:21 AM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
The first press is very short and the second press is very long. Give it a shot and let us know. Good luck.
Old Apr 15, 2022 | 02:43 AM
tigerlee's Avatar
tigerlee
I try it today and do exactly what you tell me then both key fob work.
thanks
Old Apr 15, 2022 | 09:33 AM
cor66vette's Avatar
cor66vette
thanks
N I C E !!! Thanks for letting us know,
To c8 front trunk
