Sponsored by: Wheel Design
Extended Idle Time?
Old Apr 25, 2022 | 12:47 PM
Enderthex's Avatar
Enderthex
Default Extended Idle Time?
Due to extenuating circumstances... I have a situation where I am sitting in my car, parked, with the AC on for about 1-1.5 hours at a time. I won't be able to drive anywhere during this time.
This may occur about two times a week and may occur during the 100+ deg Texas summer.
So far when I've done this with my truck there are no signs of stress or other issues, seems to handle it easily.
Is there anything I should be concerned about with the C8?
Not sure if it makes a difference but I have a Z51 Coupe.
Old Apr 25, 2022 | 12:59 PM
Lazzz's Avatar
Lazzz
In general, they say extended idling can more swiftly deteriorate head gaskets, spark plugs, battery, etc. 1-1.5 hours is a really long time for it be left idling.
Will you have any short term issues? Probably not. Would I find another way? Yeah.
Old Apr 25, 2022 | 01:11 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Funny was next to my C8 talking with a friend while the C8 was running, and it shut off in ~10 or 15 minutes. All temps were fine. Checked the forum at that time and there is a automatic shut off. BUT if you're in the car you can restart,
Just found this:
One of the newer GM safety features is Extended Parking, which automatically shuts off a vehicle’s engine after a certain period of time while the vehicle is parked. The goal of the feature is to reduce emissions and prevent potential carbon monoxide poisoning in an enclosed space. However, some owners might wish to disable Extended Parking, thereby preventing a GM vehicle from shutting off the engine when parked.
The GM Extended Parking feature automatically shuts off the engine when the vehicle is parked for 20 minutes and the key fob is not present, or after an hour when the key fob is present.
Disabling the feature is accomplished by pressing and holding the engine/vehicle start button until the driver information center displays the message “automatic shutdown off.”
This doesn’t work on all GM vehicles, but more so on the newer ones, especially those running the automaker’s new Global B electronic architecture which first debuted on the 2020 Cadillac CT5, followed by the 2020 Cadillac CT4, Chevy Corvette C8, 2021 Buick Envision, and the 2021 Chevy Tahoe, 2021 Suburban, 2021 GMC Yukon and 2021 Cadillac Escalade.
PS: Just checked the Owner's Manual and the only issues I found related to "automatic shut-off" were under remote start. It says shuts off in 10 minutes if you remote start. i never use that. It says nothing about shutting that feature off!
Old Apr 25, 2022 | 01:21 PM
Spitfire Mk1's Avatar
Spitfire Mk1
Formula 1
I really wouldn’t be concerned with new cars:; other than fuel burned and the emissions. Just keep eye temp gauge.
Police cars and car services run idle for many hours a day, at times. Many have well over 100K miles.
Old Apr 25, 2022 | 01:46 PM
MitchAlsup's Avatar
MitchAlsup
Why are YOU constrained to remain in the car while waiting ?
Could you get out and wait in an air conditioned room, office, store, restaurant ?
It is probably costing you $4-$5 to sit there idling for 1-1½ hours.
Perhaps you could go to a local bar for the duration........and brake even money wise.
Old Apr 25, 2022 | 02:12 PM
Enderthex's Avatar
Enderthex
Good suggestions but unfortunately not an option... as I said... extenuating circumstances. Cost is of no concern but I would not want to damage the car.
Old Apr 25, 2022 | 02:18 PM
Enderthex's Avatar
Enderthex
Is the concern about engine components still relevant for modern cars? I've heard this concern before and I'm sure it's valid for some cars.... Just very curious if it still holds true for the C8.
Thanks for the info, I also did not find anything about the auto shutoff... The shutoff doesn't bother me since I can just restart the car.
I appreciate the info, this is what I want to hear... Hopefully it's also correct
My truck seems to handle it easily (Tundra V8) but I wonder if the C8 has other heat issues while not moving.
Old Apr 25, 2022 | 02:19 PM
See8's Avatar
See8
" as I said... extenuating circumstances"
Lack of ingenuity? Creativeness? Thoughtfulness? Literally makes no sense. Unless of course, you are on a dedicated mission to upset Greta Thunberg, then it makes total and complete sense.
Old Apr 25, 2022 | 02:27 PM
Enderthex's Avatar
Enderthex
Yes, this is it exactly. How did you guess? I send her a picture of me sitting in the car idling... it's hard to tell it's actually running so I have to caption the image to say "it's on"
Old Apr 25, 2022 | 02:34 PM
Ken_C8's Avatar
Ken_C8
St. Jude Donor '09, '21
Now my curiosity is piqued. Can you share the circumstances around the need to idle for that long?
Old Apr 25, 2022 | 02:36 PM
bhvrdr's Avatar
bhvrdr
Extended idling is considered severe duty. Check the owners manual. Any owners manual in any modern car will at the very least half the oil change interval on severe duty. As an example one of my other cars has a 10k mile OCI but states oil must be changed at 4k miles under severe duty which includes extended idling.
Your car idling is sitting there with no significant load on the rings with fuel being injected right into the cylinders washing down the oil film. Modem cars are actually LESS tolerant of this as we use direct injection that does a great job of wetting the cylinder.
This is not to mention the lack of airflow over any and all of the heat exchangers.
This is why all police cruisers get upgraded cooling sytems. They also tend to ditch their cars right about when the engines need replacement at the 100k mark.
Id personally find another car for that duty. If for some reason you cant id do 3k to 4k mile oil changes or at least oil analysis to look at fuel dilution.
Old Apr 25, 2022 | 02:48 PM
Enderthex's Avatar
Enderthex
Logic dictates this is the most correct and relevant information to my situation. Thanks. I've known of the modifications to severe duty vehicles but maybe I was hoping it wouldn't be as necessary with new engines. Likely wishful thinking, quite unfortunate for me.
Luckily I haven't put my C8 through this torture yet... I do want it to last until the next gen comes out and then I would like to see it go to someone who can still enjoy it.. I should have well over 100k miles by then.
Old Apr 25, 2022 | 03:00 PM
Zymurgy's Avatar
Zymurgy
Moderator
From the Owners Manual:
The Additional Required Services -
Severe are for vehicles that are:
. Mainly driven in heavy city traffic
in hot weather.
. Mainly driven in hilly or
mountainous terrain.
. Used for high speed or
competitive driving.
. Used for taxi, police, or delivery
service.
Old Apr 25, 2022 | 03:07 PM
Kevin A Jones's Avatar
Kevin A Jones
Ok, you are either a private-eye trying to catch someone cheating on their wife or a stalker, which is it?
Old Apr 25, 2022 | 03:21 PM
RKCRLR's Avatar
RKCRLR
I wouldn't be that concerned about damage to the engine during idle. As mentioned, there are lot of situations that extended idle periods are part of the duty cycle. Depending on where you live, a lot of idling may be part of your daily commute. And the OLM will keep track of any reduced oil life. There isn't even a severe duty service schedule in the C8 owners manual, just extra maintenance for track use. And the OP has a Z51 so it has more than enough cooling.
I've had to idle for 1/2 hour on a hot day (road work on a 2 lane highway) and there was no indications the car was close to overheating. A message will come up on the display that the engine is going to shut off in so many minutes but if you press the brake pedal or provide other input it will continue to idle.
Obviously it would be better for various reasons not to let the car idle but it shouldn't cause damage.
Old Apr 25, 2022 | 03:26 PM
Zymurgy's Avatar
Zymurgy
Moderator
There most certainly is. Page 296 of the 2022 Owners Manual - Maintenance Schedule Additional Required Services-Severe.
Also, page 292 has this:
The Additional Required Services- Severe are for vehicles that are:
. Mainly driven in heavy city traffic in hot weather.
. Mainly driven in hilly or mountainous terrain.
. Used for high speed or competitive driving.
. Used for taxi, police, or delivery service.
​​​​​​​Refer to the information in the Maintenance Schedule Additional Required Services Severe chart.
Old Apr 25, 2022 | 03:28 PM
bhvrdr's Avatar
bhvrdr
Yeah i wasn't meaning to communicate that i think it will cause imminent damage but i do think it could easily half major components lifes doing it daily. I think of it as doing a monthly hpde versus using my car daily as a daily or weekly Spring Mountain rental lol. If its going to be idling for up to 2 hours several days per week every single week id sure want to find a beater to do that duty for me.
But Yolo so by all means. It has a warranty so why not
To Extended Idle Time?
Old Apr 25, 2022 | 03:32 PM
bhvrdr's Avatar
bhvrdr
If its a dream car and you can't do a beater who cares? Enjoy the heck out of it and if something fails early warranty it. Get an extended 120k mile warranty. Put some money away for a car repair fund. Good to go.
Heck thats the reason i got the c8. If you do pop the engine or transmission or whatever its not the end of the world even outside of warranty. A McLaren on the other hand...
Old Apr 25, 2022 | 03:38 PM
RKCRLR's Avatar
RKCRLR
Well, yes, technically there is, but there is no difference in required maintenance between the two schedules. At least I couldn't find a difference but perhaps I missed it. I noticed this when I was reading the manual before I had my car. Probably a boilerplate section.
Old Apr 25, 2022 | 03:46 PM
Enderthex's Avatar
Enderthex
I think a Torch Red C8 would make this work challenging... although if I were in Miami playing around like they do on Burn Notice maybe it would blend in
True, I do have a 75k warranty, will not be babying the car. Hoping to get some track time and lots of miles. I also have access to a lift plus full machine shop with alignment rack, etc... my friends and I are mechanically inclined so I won't mind doing extra oil changes. So far most of the vehicles we work on are big Toyotas although my buddy just bought a Lotus Elise... another Toyota motor I guess.
