Sponsored by: Wheel Design
5th gear doesn’t accelerate…
Old May 21, 2022 | 09:17 PM
Foehammer's Avatar
Foehammer
Default 5th gear doesn’t accelerate…
Looking to see what others experience here. While ripping down the highway my c8 blasts through 1st -4th, once I hit 5th gear there is definite reduction in power/acceleration. Is 5th gear just geared that way?
Popular Reply
May 22, 2022, 08:13 AM
rkrupka's Avatar
rkrupka
Originally Posted by WalterSobchak
5th is not an overdrive on this transmission. It takes you from ~ 112 - 150. It's a longer gear, but not an over drive. The power band isn't wide enough for this transmission to pull a lot of top end. In the Z06 5th is roughly 140-185 and that's with a bigger over all ratio.
1st Gear 2.91:1 2nd Gear 1.76:1 3rd Gear 1.22:1 4th Gear 0.88:1 5th Gear 0.65:1 6th Gear 0.51:1 7th Gear 0.40:1 8th Gear 0.33:1
Old May 21, 2022 | 09:41 PM
QuickSilver20's Avatar
QuickSilver20
How fast are you going when your flooring it in 5th? I believe 5th gear maxes out at around 160-170 MPH so you would have to be going pretty fast to get the RPMs high enough to where it will pull like the lower gears.
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
5th gear is an overdrive!
Old May 22, 2022 | 12:27 AM
Foehammer's Avatar
Foehammer
I should have known and thanks for confirming. It definitely feels that way. I’m new to the car scene. Are people changing the gearing on the c8. Though my assumption would be that it wouldn’t matter much without a tune
Old May 22, 2022 | 12:39 AM
4thC4at60's Avatar
4thC4at60
You in tour mode? Or.....?
Old May 22, 2022 | 01:49 AM
WalterSobchak's Avatar
WalterSobchak
Old May 22, 2022 | 08:13 AM
rkrupka's Avatar
rkrupka
Old May 22, 2022 | 09:29 AM
ea327's Avatar
ea327
Banned Scam/Spammer
see post#7
Old May 22, 2022 | 10:24 AM
WalterSobchak
You are forgetting the drive ratio...... 5.17. it's literally half the equation. So 5th gives you 3.37:1 overall....
In a C7 7spd 4th gives you 3.42(3.42:1:1)......
Old May 22, 2022 | 10:25 AM
WalterSobchak
Originally Posted by ea327
see post#7
See post #9
Old May 22, 2022 | 10:43 AM
SECLT22021's Avatar
SECLT22021
Anything higher than 1:1 in the transmission is not considered an overdrive gear. With your math the car doesn't have any over drive gears. Even 8th 0.33:1 = 1.70:1
Old May 22, 2022 | 10:48 AM
rkrupka's Avatar
rkrupka
I am not forgetting anything - in past cars I have replaced final drive ratios from 2.73 to 5.77.
It does not change the fact of how I am driving the driveshafts prior to the rear gear - overdriving or under driving it.
Old May 22, 2022 | 10:50 AM
rkrupka's Avatar
rkrupka
Please see post #11
Old May 22, 2022 | 11:02 AM
Mike's LS3's Avatar
Mike's LS3
Although 4th gear (.88) is an overdriven gear itself, however the addition of the DCT's transfer gear, the overall multiple is 4.56. 5th gear overall multiple is 3.36 on a Z51 and 3.18 on non Z51 which now becomes overdrive. Short story, overdrive in a C8 starts in 5th gear because of the overall gear multiples.
C8
Trans gear x differential gear (3.55) x transfer gear = overall gear ratio. Any overall gear ratio below 3.55 is overdrive.
C7
Trans gear x differential gear (3.42) = overall gear ratio. Any overall gear ratio below 3.42 is overdrive.
Old May 22, 2022 | 11:11 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old May 22, 2022 | 11:18 AM
rkrupka's Avatar
rkrupka
ASE definition of drive...
https://www.freeasestudyguides.com/gear-ratio.html
Old May 22, 2022 | 11:20 AM
rkrupka's Avatar
rkrupka
C8
C7
To 5th gear doesn’t accelerate…
Old May 22, 2022 | 11:23 AM
Mike's LS3's Avatar
Mike's LS3
Does not apply for C8 with a transfer gear, but applies to C7.
Old May 22, 2022 | 11:49 AM
rkrupka's Avatar
rkrupka
It applies to all cars and trucks not just corvettes - it is a definition not an opinion.
Please read the linked site for clarity.
Old May 22, 2022 | 12:07 PM
RKCRLR's Avatar
RKCRLR
I agree with the above. But the term overdrive doesn't have much meaning with respect to performance these days.
In the "early" days the output ratio of the highest gear in the transmission was 1:1. There were separate overdrive units would make the output shaft turn faster than the input shaft which enabled higher speeds top speeds with low (high ratio) rear end gearing. Then transmissions started coming with additional higher gears that turn the output shaft faster than the input shaft and these were referred to as overdrive transmissions and overdrive gears which is consistent with the definition. Whether or not a gear is an overdrive gear these days doesn't have much meaning. What is important is to have the transmission in the correct gear for the conditions.
