Rear Mirror Camera
FWIW, my camera's picture is beautiful.
@Corvette03051
@Bird67 Maybe it’s my eyes and you can look at my camera sometime and show me yours. Could my expectations be too high or maybe my eyes 👀 are just not able to focus well.
@Corvette03051
I’ve tried all positions and angles. With snd without glasses. No help for me oh well if you guys see clearly than it must be only some of us. questions: why doesn’t that happen with our rear view cameras? Is it a different type lense and why can’t it work as a mirror camera is it because it’s wide angle? Now I’m curious
Maybe there really is an issue with your's then. As for the back up camera, it doesn't happen there because when you look at it 1) your not expecting it to be a distant image and 2) if you have bifocals or progressive lenses in your glasses, you are looking down through the reading part of the lens
I don’t wear bifocals and only have glasses for reading after cataract surgery. Could be my eyes but then why do some others have a problem as well? I’m gonna drive by MM and ask them to look at the mirror camera. Thanks for the input to all.
If you need a prescription for near vision (e.g, reading glasses), taking off your glasses isn't going to help either.
When on camera, the focal length is the distance from your eye to the surface of the mirror, just as it is when sitting and looking at your computer monitor. In other words close.
When on standard mirror, the focal length is the distance from your eye to the mirror + the distance to the object you are looking at. In other words distant.
The brain and the eyes must make this distinction and it isn’t automatic, though it has seemed to improve dramatically for me with practice.
People with significant myopia requiring bifocals or progressive lenses will have to adjust more to this with a slightly different head tilt when changing from one to the other.
Top Up camera view:
Because of the higher location of the camera the field of view is much wider than any mirror I have ever had especially in the wide-angle setting. Must remember that “objects are closer than they appear”. In the narrower settings the horizontal FOV seems similar to the mirror but there is still much better visibility down low than with the mirror because of the “hump” in the tonneau cover.
Top Up mirror view:
FOV mildly to moderately limited by nacelles and tonneau cover.
Top Down mirror only:
Identical to top up mirror.
The brain and eyes are a remarkable combo and will adjust to these changes given time.
Hopefully it will get better with time.
just came in from my first after dark drive and it was horrible imo just didn’t work for me. Shut it down and used my side mirrors and rear window. Much better and it instilled the confidence I was lacking trying to make the system work.
The brain needs time to adjust to the changing focal length. Your brain expects to focus in the distance after years or decades of driving with a standard mirror.
Try sitting or driving for short periods of time and focus on the edge of the mirror first and not directly on the following car. Then let your eye drift over to the image.
Keep trying with it!
Have patience! You are not unique.
I am 70; was in progressives for years; Have had my cataracts removed and Multifocal IOLs within the last year.
I had some initial difficulty but got over it quickly.
If you can read your dash and the infotainment screen, then you can focus close enough for the mirror without additional glasses, etc.
Vision is highly dependent upon the brain to interpret the images while the eye performs primarily as a camera.
The brain is needed to tell the eye where to focus. It does all of this more or less automatically, but it relies on prior learning to aid it in doing the job.
For all of your prior life, the brain has told the eye to focus on the car far away in your mirror. Now it doesn’t understand why that “car” is suddenly 18” from your eye.
It WILL relearn the process!
Apparently LEDs must not be continuous but actually consist of very rapid flashes that we normally can’t see.
The frame rate of the camera must be such that it creates a strobe effect and you can see them flickering.
