fluid changes
Here is the post that started a long thread. Note that this was prior to GM announcing that they would extend the compensation for the first service to 2 years:
I was at Corvettes at Carlisle today, and there were a couple of presentations by GM personnel that provided some useful information, and cleared up some confusion or misconceptions.
First was a presentation by two people introduced as the program manager for the DCT project and another identified as the Assistant Chief Engineer for the DCT. Both are GM employees, not Tremec. They emphasized the importance of doing the DCT filter change at about 7500 miles to ensure all the break-in wear products are removed. Wear products that continue through those first 7500 miles, no matter how long it takes to get there. The key point was that if you put few miles on your C8, and take advantage of the "free" filter change in the first year with only a few thousand miles on the car, you should change it again at 7500 miles to remove the wear products that accumulate after the early change.
They also emphasized the importance of adding the extra 2 quarts (yes, I know it's actually liters, but even they said quarts) if you "are tracking the car." They said in something like a fast down hill turn, the oil can actually be lifted into the top of the transaxle, causing the oil pick up to suck air. I asked them to define "tracking." Does that include a few lead / follow laps at NCM, or HPDEs, or only if you're near racing speeds?
Their answer was two-fold: First, that they think GM is changing the wording of the recommendation to "tracking or spirited driving," and second, that they would define track use as anytime the car is on a track, even lead-follow laps. I think there's been a general consensus that a few laps at far lower than racing speeds doesn't really need the extra oil. This advice seems to contradict that.
(Don't argue with me - I'm just the messenger.)
They also said a replacement DCT, out of warranty, costs $20,000!
Next was a gentleman named Paul (forgot his last name - sorry) who is the manager who deals with customers or dealers when someone is seeking an accommodation for a problem / repair that is outside the warranty. The bulk of his presentation amounted to "follow the recommended maintenance and the OLMs." He also recommended letting the dealer do the DCT filter change, because the dealer tech will (a) first do the DCT flush procedure to remove as much wear material from the oil as possible. Also, after the filter is replaced, the tech will do a pressure test to ensure there are no leaks. Neither of which can be done at home without the GM software.
I think this eliminates any question about whether the flush is part of the filter change procedure or not.
