Sponsored by: Wheel Design
SD card
Old Jul 12, 2022 | 01:43 PM
befree2spin's Avatar
befree2spin
Default SD card
Any recommendations for an SD card for the C8?
Old Jul 12, 2022 | 02:06 PM
Hockeyfun1's Avatar
Hockeyfun1
I bought SanDisk High Endurance 256GB and so far so good.
Old Jul 12, 2022 | 02:07 PM
MarZZ's Avatar
MarZZ
I have both the Samsung Extreme Plus 512 GB ($199) and cheap MicroCenter 512 GB ($54) and the both work fine. I get >1000 minutes left for months of continuous recording. I don't notice a difference between either of them.
Old Jul 12, 2022 | 02:16 PM
Clc3251's Avatar
Clc3251
I bought this 256gb one:
Amazon Amazon
Museum formatted it for me and it works flawlessly.
Old Jul 12, 2022 | 02:27 PM
MarZZ's Avatar
MarZZ
I do like the micro with the adapter just because everything uses micro sd now. SD seems to be losing favor due to the size of the card.
Old Jul 12, 2022 | 03:35 PM
nhlgopens's Avatar
nhlgopens
SanDisk 512GB Extreme PRO SDXC UHS-I Card - C10 from Amazon for $115. Works perfectly.
Old Jul 12, 2022 | 04:04 PM
Sdk8103's Avatar
Sdk8103
Has anyone seen, or figured out, how many hours each of these memory cards will last without it over writing?
Old Jul 12, 2022 | 05:09 PM
RIrvine's Avatar
RIrvine
My 32 g says 300 hours. Cant say I believe it yet
Old Jul 12, 2022 | 07:24 PM
NextOne's Avatar
NextOne
@befree2spin I bought one of the recommended ones from Amazon. Caused me lots of problems with recordings that I couldn't figure out----until I bought a another similar card at my local Target. Just saying to be cautious of any you buy from Amazon and to know that recording issues may well be a bad card problem.
Old Jul 12, 2022 | 07:34 PM
befree2spin
https://www.amazon.com/dp/B07YFGS6LJ...roduct_details
What do you mean when you say the museum formatted the card?
Old Jul 13, 2022 | 11:41 AM
thebroz1138's Avatar
thebroz1138
Perhaps the most important requirement is "Class 10" which describes the speed which the card can accept and record data. Most cards I see for sale are at least Class 10, sometimes just described as C10.
I got one of these from Amazon, and it's been fine.
SanDisk 256GB Extreme SDXC UHS-I Memory Card - 150MB/s, C10, U3, V30, 4K UHD, SD Card - SDSDXV5-256G-GNCIN
Old Jul 13, 2022 | 11:47 AM
johnodrake's Avatar
johnodrake
Moderator
I use this card from
Amazon Amazon
Old Jul 13, 2022 | 12:00 PM
markb01's Avatar
markb01
I just purchased a SanDisk 64GB Extreme SDXC UHS-I Memory Card. Only $13 on Amazon. Not as much time as a 256G but not sure I need more. Covers a full day drive and if there is something I want to keep, I'll just copy it over.
Old Jul 13, 2022 | 02:34 PM
gdb069's Avatar
gdb069
I bought this one SanDisk Ultra 128 GB UHS-I SDXC - Walmart.com but for some reason here in Canada at Bestbuy it was only $14. I see people are paying $100-200 for larger cards but not needed. I bought mine in November and it is a daily driver so hundreds of recordings at hi-res and audio. When I got to half full after 6 months, I copied some interesting ones to my laptop and just reformatted the drive that took about 20 seconds. 128GB is more than enough available space but it was actually cheaper than the 32gb and 64.
Old Jul 13, 2022 | 03:03 PM
Andybump's Avatar
Andybump
I got this one. Did not require any formatting. Works fine. Says I have "over" 1000 minutes of time. Does not say how much over, but it has said that for 2500 miles and I have never deleted any videos.
Old Jun 10, 2023 | 04:06 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Just an FYI, you really don't need these gigantic 256 & 512 Gig cards. The biggest file I have recorded with the PDR is a 29 minute track session, file size 1.25 Gig.
The most important part is that you buy a Class 10 card
Old Jun 11, 2023 | 06:55 PM
SCorvette08's Avatar
SCorvette08
I paid $11 at Walmart 64 scan disk works flawlessly no issues
To SD card
Old Jun 11, 2023 | 11:44 PM
johnodrake's Avatar
johnodrake
Moderator
I have had my 512 GB version in the car for over two years and it still says 636 minutes remaining. It records every time I start the car.
Old Jun 12, 2023 | 09:52 AM
Walt White Coupe's Avatar
Walt White Coupe
To me that sounds like you have a problem since the time remaining should change every time you start the car.
Old Jun 12, 2023 | 12:50 PM
Walt White Coupe
That sounds like a scam that is very common when it comes to memory cards, disks, etc., especially coming from China. That card maybe only a 1 or 2 Gig card that has fake coding that a computer will read as 512 gigs until you try to load it up with data. The C8 system will load it up to its real capacity and then rewrite over it when full. You might not even realize that the card is not the advertised capacity.
$10 is way too cheap for 512 gigs.
