Sponsored by: Wheel Design
Need help c8 corvette convertible top squeaking
Old Jul 18, 2022 | 07:50 AM
natsuki_tri's Avatar
natsuki_tri
Navigator
Default Need help c8 corvette convertible top squeaking
Hello , I just get my c8 corvette HTC and i run around 400km , I heard the squeaking from the rear middle windows behind the driver and passenger seat.
When i open the mirror or hard top down the squeaking gone. so i read old thread its can resolve with 3m dielectric grease but i dont know where can i paint or apply it. If someone know or have this problem before and get resolve please help thank you so much.
Old Jul 18, 2022 | 02:10 PM
Korbek's Avatar
Korbek
It's most likely the rubber seal around the perimeter of the window squeaking when the top is up. Grease the very top edge of the rear window with the top lowered and the window raised fully so you can get a thin line all the way across the top edge. About 1/4-1/2 inch of greasenalong the top edge. That *should* fix it unless the squeaking is coming from the HTC motor assemblies.
Old Jul 18, 2022 | 02:17 PM
Skid Row Joe's Avatar
Skid Row Joe
Would suggest using Vaseline, instead of automotive grease. ^^^^
Old Jul 18, 2022 | 02:33 PM
Warp Ten's Avatar
Warp Ten
Or better yet.. go to your local Chevy, Buick or GMC dealer and have them put the OEM window grease on it. When I got my 2021 HTC the back window had some clear grease smudges on it... I wipe it off the window , but it came back every time I opened it. After 12 months it stopped smudging the window, but the squeak didn't return
Don't need a specially trained Corvette teck to do that..
Old Jul 18, 2022 | 02:35 PM
Korbek's Avatar
Korbek
Vaseline can be worse. I recommend using Gummi Pfledge (on the rubber seal). I used it on my HTC weather seals for years on my SLKs and it was aces. Vaseline can actually break down any rubber seals exposed to it.
Or as above poster said, OEM window grease on the window.
Old Jul 18, 2022 | 05:44 PM
Skid Row Joe
Exactly what's worse about Vaseline vs. automotive grease ?? My Chevrolet dealer uses Vaseline, so it cannot be worse than petrochemical grease.
Old Jul 18, 2022 | 05:57 PM
RKCRLR's Avatar
RKCRLR
If your dealer uses Vaseline on weather stripping you need to find another dealer. Your dealer should be using GM approved lubricants (silicone based) on the weather stripping. Petroleum based products will degrade the weather-stripping.
Old Jul 18, 2022 | 06:12 PM
Skid Row Joe
Well, they probably use WD-40 too. GM approved? Who knows...
Old Jul 18, 2022 | 06:28 PM
Fast Boat Guy's Avatar
Fast Boat Guy
My dealer says to use dielectric grease on it.
a very very small amount, put it on, let it sit for 5 min, the. Wipe the excess off.
should work.
Old Jul 18, 2022 | 08:22 PM
trynt's Avatar
trynt
This works:
Amazon Amazon
Old Jul 18, 2022 | 09:10 PM
Korbek's Avatar
Korbek
See below (although I already mentioned it in my post above).
This. Petroleum jelly (vaseline) will degrade rubber weather stripping. Bad idea. I've been driving HTCs since 2008 and avoid the stuff. I've never had a single squeaky HTC seal or leak in any of the 4 HTCs I've owned. (5 now counting the C8)
I didnt say to use automotive grease. I said to use Gummi Pfledge bc it is designed for use with wrather stripping. But really any similar product would work. I just recommend OP absolutely NOT use vaseline. You do you though.
Old Jul 18, 2022 | 10:49 PM
Mike's LS3's Avatar
Mike's LS3
should work.
GM uses Dielectric grease. Rub on thin coat, allow the weatherstrip to absorb the grease for 10-15 minutes. Then wipe off excess.
There was a You tube video that Rick Conti did with his Corvette service technician. They did exactly what is described above. Don't use other chemical products because they will only deterioate the weatherstip in time.
Old Jul 18, 2022 | 11:14 PM
Hockeyfun1's Avatar
Hockeyfun1
My dealer said don't do that with the dielectric grease and said they had complaints about it and reached out to GM. GM had a fix and said something needed to be tightened. Just read my repair bill:
contact tech assist center, advised on recommendation to R&I rear sliding window motor for possible retorque to fasteners. (Lists a bunch of numbers and some letters) removed rear covers to access rear window motor regulator, verified retaining bolts not properly torqued. Torqued all fasteners to spec and reinstalled.
Old Jul 18, 2022 | 11:22 PM
natsuki_tri
Navigator
Thanks a lot i will try to fix it and will update later 🥲
Old Jul 18, 2022 | 11:28 PM
natsuki_tri
Navigator
Can you please give me a link? Thank you. 😊
Old Jul 18, 2022 | 11:56 PM
Greg00Coupe's Avatar
Greg00Coupe
Why not just open the rear window just a hair? I bought the grease but it’s so much easier and cleaner to just crack the rear window! No noise,no rain gets in, I just close it when I wash the car.
Old Jul 18, 2022 | 11:59 PM
Hockeyfun1's Avatar
Hockeyfun1
I was doing that but thought it's silly to have to do that. I thought it's silly to add dielectric grease too. I brought it to the dealer because it simply shouldn't rattle, and they had a fix that I posted in my last post.
To Need help c8 corvette convertible top squeaking
Old Jul 19, 2022 | 12:23 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
This:
Old Jul 19, 2022 | 12:55 AM
Skid Row Joe
I know you didn’t. I did. I wasn't responding to you. The OP wrote grease - you went off on a different tangent. Thx for the info. My Chevrolet dealer used Vaseline - that wasn't my call in the first place. Certainly not Petroleum grease! As suggested...
Old Jul 19, 2022 | 11:45 AM
RKCRLR's Avatar
RKCRLR
Vaseline is petroleum based. There are petroleum based greases, silicone based greases, etc. Grease is a generic term.
