Sponsored by: Wheel Design
Lowering Question
Old Sep 2, 2022 | 01:30 PM
jost6453's Avatar
jost6453
Default Lowering Question
I have a ‘23 HTC Z51 without the adjustable front lift option. I’d like to lower the front slightly (1/2” ?). How much height change do you get from 1 turn of the coil collar? Of said another way, how much do you turn the collar to achieve 1/2”
drop? Thx.
Old Sep 2, 2022 | 03:26 PM
c7steve's Avatar
c7steve
on my HTC Z51 ,,,,I lowered mine on four corners all the way except for the last 2 threads. from my measurements it lowered about 3/4 of a inch
Old Sep 2, 2022 | 03:31 PM
progtp's Avatar
progtp
I got the same result. Adjusted all the way down was .75".
Hopefully this helps you figure out a 1/2 inch. Good luck!
Old Sep 2, 2022 | 10:45 PM
Kvou812's Avatar
Kvou812
I lowered mine all the away around - Non-Z51 with mag ride, no front lift. I do have wheel spacers however.
Old Sep 3, 2022 | 06:32 AM
acrace's Avatar
acrace
The track prep guide says each full turn of the spring seat is 0.06” (1.5 mm) of ride height adjustment.
https://www.chevrolet.com/content/da...reparation.pdf
To Lowering Question
