Sponsored by: Wheel Design
Proclip mount
Old Sep 10, 2022 | 03:18 PM
saleen556's Avatar
saleen556
Default Proclip mount
Installed the Proclip phone mount today. Works perfectly and is easily accessible as well. Definitely won’t forget it when getting out🤣
Old Sep 10, 2022 | 05:25 PM
1__more's Avatar
1__more
Another vote for Proclip! I'm very happy with mine.
Old Sep 10, 2022 | 05:40 PM
saleen556's Avatar
saleen556
I love how it’s such a simple design and puts the phone at the perfect height near the screen.
Old Sep 10, 2022 | 07:31 PM
Zormecteon's Avatar
Zormecteon
I like it EXCEPT for the phone holder itself. If you turn the phone horizontally, it can slide out going around a corner!.. I got the ball mount attachment and use a IOtti phone holder.. Best of both worlds.
Before the ProClip I tried at least 2 other mounts.. Nothing even close to the PRO Clip
Old Sep 10, 2022 | 07:35 PM
saleen556's Avatar
saleen556
That’s the great part of the mount. You can put a nice variety of holders on it. I was considering a magnet for it but I use the wireless charger in my TRX.
Old Sep 11, 2022 | 10:51 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice, I need to consider this mount.
Old Sep 11, 2022 | 11:21 AM
jerseymike's Avatar
jerseymike
Default Pro clip mount
[QUOTE=peter pan;1605661140]Nice, I need to consider thus]
I too need to consider this option. Every time I get out of the car I forget my phone. It is difficult to reach in and try to grab it.
it does not look like an obtrusive option, which I like. No screws, holes or double stick tape.
Old Sep 11, 2022 | 12:18 PM
saleen556's Avatar
saleen556
[QUOTE=jerseymike;1605661252]
Yes it just wedges behind the screen and clips on the edge. Definitely the easiest mount I’ve installed.
Old Sep 11, 2022 | 01:01 PM
David.L's Avatar
David.L
can you provide a link to this one? I searched on Amazon and there seems to be a few holders called ProClip. I want to make sure I order the one that you have. This seems to be exactly what I need.
Old Sep 11, 2022 | 01:19 PM
G8R-Vette's Avatar
G8R-Vette
Here ya go: https://www.proclipusa.com/collectio...-corvette-2022
Old Sep 11, 2022 | 01:55 PM
saleen556's Avatar
saleen556
Make sure you order the correct holder for your phone as it’s separate from the mount. They also just had a 15% off sale. Not sure if it’s still going.
Old Sep 11, 2022 | 02:25 PM
scithera's Avatar
scithera
One thing to note is that the mounts are on backorder until the week of Oct 14th. I placed my order 2 weeks ago and that was the latest from them.
Old Sep 12, 2022 | 12:35 AM
VegasAlleycat's Avatar
VegasAlleycat
So you use a ProClip but with an IOtti holder? Do you have a link for the specific IOtti phone holder/attachment?
Old Sep 12, 2022 | 01:54 PM
Zormecteon's Avatar
Zormecteon
I bought the EASY ONE TOUCH... took the phone holder off the mount and put it on the 17 mm ball. .. No,,.. wait, ... for the C8 I took the holder from the CD car mount because it didn't have the bottom bracket. .. though those are easily removed.
The ball that PRO CLIP sells is 17 mm as this is the standard ball size. .. Pick YOUR favorite phone holder and use that. I like the IOtti because I only have to push the phone against the button and it's held, and squeeze the sides to release. .... Easy Peezy.
Old Sep 13, 2022 | 08:00 AM
Undy's Avatar
Undy
Darn, sure would like to get one for my phone...but... they don't make a QI charging holder to fit my phone/case (Samsung Note 9 with a Otterbox Defender case). Without QI charging it's useless in my case.
Old Sep 13, 2022 | 08:20 AM
McClendons's Avatar
McClendons
If you get the proclip Corvette adapter (part that mounts to screen), nearly any phone mount will then bolt to it. You do not have to get a holder from proclips as well.
Old Sep 13, 2022 | 11:24 AM
Zormecteon's Avatar
Zormecteon
Right-ee-O. PRO-CLIP base, 17mm ball, (from PRO-Clip) your favorite phone holder and Bob's yer Uncle. It's not an inexpensive way to go, but it sure works great. .. I can even turn my phone horizontally and not have any part cover the C8 screen.
To Proclip mount
Old Sep 13, 2022 | 02:16 PM
jerseymike's Avatar
jerseymike
Default Bob’s
You got a link to that? Proclip holder, yet backordered is another 35$.
Old Sep 13, 2022 | 04:56 PM
Zormecteon's Avatar
Zormecteon
https://www.proclipusa.com/products/...-adapter-plate
https://www.proclipusa.com/collectio...-corvette-2021
It took some searching but here's the combo..... THEN
iOttie Easy One Touch Mini Dash & Windshield Car Mount Phone Holder || iPhone Xs Max R 8 Plus 7 Samsung Galaxy S10 E S9 S8 Plus Edge, Note 9 & Other Smartphones iOttie Easy One Touch Mini Dash & Windshield Car Mount Phone Holder || iPhone Xs Max R 8 Plus 7 Samsung Galaxy S10 E S9 S8 Plus Edge, Note 9 & Other Smartphones
The above is the cheapest IOttie mount. There are others but this one doesn't have a bottom piece, I've never had one drop the phone.
Old Sep 15, 2022 | 12:36 PM
Red Mist Rulz's Avatar
Red Mist Rulz
I've used Proclip mounts in a number of cars. They're pricey, but the best integrated mounts around. They use the standard AMPS mounting hole pattern for the phone holder, so you can use any holder you want that also uses AMPS. That's a very long list.
