Sponsored by: Wheel Design
Underbody Panel Identification.....?
Old Oct 8, 2022 | 06:16 PM
LT2/3LT's Avatar
LT2/3LT
Unmodified C8 of the Year 2021 Winner
Default Underbody Panel Identification.....?
Anyone help to identify this underbody panel? Searching GM parts, I can only locate 3 underbody panels and none that match this one.
Old Oct 8, 2022 | 10:51 PM
C8NCA's Avatar
C8NCA
I believe that is referred to as the Front Tire Front Air Deflector. the center panel appears to be the Front Bumper Fascia Lower Stiffener.
Old Oct 8, 2022 | 11:12 PM
NoMatter's Avatar
NoMatter
What’s Next
Believe this is it. Don’t see it as left and right so it may be a set. I’ve ordered some parts from them listed the same way but I’d make sure.
With Z51
Without Z51
Old Oct 9, 2022 | 12:47 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
With Z51
Without Z51
I actually had to replace the passenger (right) side one on my Z51 C8. I bought it at the local dealer who just happened to have one in stock for another customer who abandoned the order. It came in a big box that had both left and right panels, and all the mounting clips and screws. Cost was $117, and an easy replacement (once the car is lifted some).
Old Oct 9, 2022 | 09:46 AM
LT2/3LT's Avatar
LT2/3LT
SP & Mark....thank you. I came across this link also after my post yet was unsure if order came with both left/right as the drawing showed only drivers' side and was unable to determine if there was an additional item number for the left. Thanks for the clarification. Time to shop! And....if I took the time to read the full description, it clearly states package contains both left and right panels!!
Old Feb 16, 2023 | 01:04 PM
C8Magnum's Avatar
C8Magnum
5th Gear
What is the difference between the Z51 and non Z51 part?
Old Feb 17, 2023 | 12:39 AM
Avanti's Avatar
Avanti
"...difference between the Z51 and non Z51 part" Click on the two links in the post above... about 12-bucks.
Old Feb 17, 2023 | 05:24 AM
C8Magnum's Avatar
C8Magnum
5th Gear
The reason I ask is because I purchased the one for my Z51 car and it came with an extra flap riveted in the center that my take off part doesnt have...none of the pictures show that area.
Old Oct 24, 2023 | 12:00 PM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Bottomed out bad the other day. Thankfully, all the damage was to these two plastic panels. I just ordered replacements using the link above. I really appreciate this website!...
Old Nov 19, 2023 | 11:19 PM
prosunseeker's Avatar
prosunseeker
I also have that lower bump out on my non-z51. Did you find the right parts?
Old Dec 22, 2024 | 05:13 PM
1219chicho's Avatar
1219chicho
Just had it happened to me. I ordered the part can i just replace the rubber piece without the entire panel?
To Underbody Panel Identification.....?
