Sponsored by: Wheel Design
Steering
Old Oct 25, 2022 | 09:09 PM
akdredger's Avatar
akdredger
Default Steering
I have 200 miles on my new HTC, when I am stopped, say to pull into parking spot or other sharp turn. The front feels like a 4wd truck in 4 wheel drive on dry pavement. Herky jerky.
Anyone else with this problem?
Old Oct 25, 2022 | 09:18 PM
tmatt182's Avatar
tmatt182
hi! I have 2023 with 350 miles. I have noticed the same thing. I attributed it to the tire break in. I have Z51 so I assume maybe tired related due to stickies on it, but really didn’t put much concern into it.
RKCRLR's Avatar
RKCRLR
Cold weather? Z51?
It is a known condition with summer tires in cold weather due to the effect of partial Akerman steering during sharp turns.
Old Oct 25, 2022 | 09:35 PM
akdredger's Avatar
akdredger
Originally Posted by RKCRLR
Cold weather? Z51?
Yep, 30s here in Alaska. Was trying to drive it before storage. It's is a Z51.
Old Oct 25, 2022 | 09:39 PM
David.L's Avatar
David.L
That is most likely it. The tires on the Z51 are rated to 40f.
Old Oct 25, 2022 | 09:59 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Cold weather? Z51?
Yep, it’s more that rubber tired cars don’t need full Ackerman compensation for very sharp slow turns to offset the difference in turning ‘radius inside to outside tire. The tire slip angle provides some of the difference so less is built into the steering geometry. Performance tires have lower slip angles.
However Tadge said they did not need the more race car type tire construction in the C8 Z51 as used in the C7 where chatter or “hopping” as GM referred to it was very pronounced. It was really bad below about 45 F. I have verified my C8 Z51 is not nearly as bad as my C7 Z51 and Grand Sport. In the winter I was using a “K” turn when I backed my C7 out of my garage to go down the driveway. No need in the summer. But it’s not that bad at >45F with the C8. But suspect at ~35 F it might be.
This is a detailed PDF re Ackerman and why limited Ackerman compensation allows higher max lateral “g” force at higher speeds.
http://netwelding.com/Wheel_Chatter.pdf
But if those comments are occurring at 50 - 55F or more there is an issue with the electric power steering. My Z51 has no unusual feeling on full-lock slow speeds at those temps.
Old Oct 25, 2022 | 10:19 PM
Kevin A Jones's Avatar
Kevin A Jones
Exactly, it's the Ackerman effect, C7 has the same behavior.
Old Oct 25, 2022 | 10:45 PM
akdredger's Avatar
akdredger
You guys are way more knowledgeable than me. 4x4s I know things. Corvettes, I can't figure out the seat buttons, radio and 1000 other things......yet.
Old Oct 26, 2022 | 12:48 AM
Old Oct 26, 2022 | 06:42 AM
JerryU's Avatar
JerryU
But Tadge said they did not have to use the race car type tires as needed on the C7 so IT DOES NOT HAVE THE C7 CHATTER!
Know most will not look at my many pic/long caption PDF so this is a quote:
With the introduction of the C8, Tadge Juechter, the Corvette Chief Engineer provided some perspective as to the reason the C7 was very bad, much worse that my C6 Z51 when below 50 F and especially at 40F. In a 1+ hour interview on Autoline Afterhours he said they knew they pushed the FE Corvette design as far as they could when they were concerned the 2009 C6 ZR1 with it’s 638 hp supercharged engine was not able to even match the 0 to 60 time of the Z06 with only 505 hp! He said the added front weight of the ZR1 supercharger and intercooler added more weight on the front wheels and did not provide the needed traction for faster 0 to 60 times. He said the barely squeezed by using very special race car type, sticky tires!”
Answering a question at the 1st C8 BASH Tadge said they did not have to use race car type tire construction in the C8 so it does not have the C7 Z51 “Chatter.” I have found it is much better and I don’t have to turn less than full lock and use a “K” turn to drive down my driveway after backing out of my garage when it’s ~45F. I use full lock as I did with my Grand Sport in the summer. There is some slight chatter more like my C6 Z51 but nothing like my 2017 Grand Sport when cold. But suspect when below ~45 F you will feel some chatter. Fortunately I seldom have to drive when below ~40F.
Old Oct 26, 2022 | 12:14 PM
Fast Dawg's Avatar
Fast Dawg
I have a non-Z51 C8 and I feel the Ackerman effect on cold tires. It startled me when I first felt it on my C7. After the tires get warm it goes away.
Old Oct 26, 2022 | 04:39 PM
Jbravo_AK's Avatar
Jbravo_AK
Which part are you in? I know theres not too many C8 owners in Alaska. I'm up Fairbanks way.
Old Oct 26, 2022 | 04:45 PM
wrecker3's Avatar
wrecker3
Get All Season Tires and it will go way !!
Old Oct 26, 2022 | 04:50 PM
TKKRCats's Avatar
TKKRCats
It is the tires that cause the "chatter" or "hopping" feeling when making the sharp turns in colder weather on cold tires. I picked up my car Z51 in December 2020 and was warned or given the heads up about it during my Museum Delivery. After being home a couple days, I swapped out my wheels and installed all-season tires, instant difference making turns in my driveway.
Old Oct 26, 2022 | 04:51 PM
akdredger's Avatar
akdredger
Wasilla. Probably 8-12 of us up here.
Old Oct 26, 2022 | 06:11 PM
JerryU's Avatar
JerryU
Yep same with the C7, even more so. With the same Ackerman steering geometry all season tires had no chatter where Z51 were terrible. Performance tires have low slip angles, conventional tires more. The compound also "gives less" in performance tires when cold.
Yep GM could have used more Ackerman steering geometry to eliminate chatter with the Z51 BUT at higher speeds you get less lateral "g" performance. The research I did is in the PDF and defines why.
To Steering
