Sponsored by: Wheel Design
Extra HP
Old Oct 25, 2022 | 10:38 PM
CMGC8HTX's Avatar
CMGC8HTX
Default Extra HP
At this point, what is the best ways outside or supercharging to add HP to C8? And is there any known tunes available to make it actually work?
Old Oct 25, 2022 | 10:48 PM
Maxie2U's Avatar
Maxie2U
Your post begs that question why do you need more HP? Do you plan to drag race?
Old Oct 25, 2022 | 10:52 PM
darkling's Avatar
darkling
from what has been said. Yes it has been cracked. But it's a waste of time only thing yoyu can do is fuel trim and alittle timing. but as for extra hp it's maxed out . even the supercharge is using Lingenfelter box for fuel .
Old Oct 25, 2022 | 11:17 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Why people want to question what you're asking about is beyond me. All that matters is what you want!
GPI has done twin turbos and with no tune. Lingenfelter has a Magnuson Supercharger package that somehow doesn't use a "piggyback" device. Both are pricey.
Old Oct 26, 2022 | 12:01 AM
PhoenixM3's Avatar
PhoenixM3
He asked for extra horsepower, not more horsepower. Get it right……Man!
Old Oct 26, 2022 | 12:05 AM
Avanti's Avatar
Avanti
Unless virtually starting from scratch, mainly bench-racing bolt-ons.
Old Oct 26, 2022 | 08:12 AM
bthibodeaux's Avatar
bthibodeaux
It’s not a matter of need. Just like the car itself, it’s a want. The same want that many have. Hence the popularity of the Z06, Eray, and other variants.
Old Oct 26, 2022 | 08:21 AM
Shoal07's Avatar
Shoal07
2022 C8 of the Year Finalist - Unmodified
Without forced induction, anything to get air in and out more easily is about the best you can do. Intake, throttle body, cats, exhaust. You can probably get 30-50 through bolt ons.
Old Oct 26, 2022 | 08:41 AM
TD20's Avatar
TD20
Just get an air filter, easy way to get some more HPs for $200.
Old Oct 26, 2022 | 08:49 AM
Fishfryer527's Avatar
Fishfryer527
More power is always better, try turning off the traction control and seeing how often you are using what the motor gives you. Modern cars are very good at self-preservation, this is why rich old blue haired ladies love their AMGs, they’re stylish but castrated.
After driving a car with minimal electronic help, then maybe you can see if minors changes and not forced induction will be enough to make you happy.
Old Oct 26, 2022 | 09:19 AM
GP37's Avatar
GP37
so far the biggest gains i have seen on an NA C8 is ported heads, but that runs about 6-8k to drop the engine and do the porting. Competition auto got 519 whp with this along with headers, cats, exhaust, intake, ported throttle body, and ported intake manifold.
Old Oct 26, 2022 | 09:42 AM
Fore58's Avatar
Fore58
Just go in the Tech/Performance Section and that should tell you all you need to know.
Old Oct 26, 2022 | 12:46 PM
Chotis Bill's Avatar
Chotis Bill
One thing that looks pretty tame is the cam timing. From dyno test I have seen there are good gains to be had with a cam with more duration and lift.
Old Oct 26, 2022 | 01:26 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Good luck with 50 HP. Or even 30.
Most manufacturer claims are exaggerated, And if you add an intake that claims 10 HP, and exhaust that claims 20, and a throttle body than claims 15, you're not going to see 45 HP gain in total. It simply doesn't work that way.
Old Oct 26, 2022 | 03:06 PM
BearZ06's Avatar
BearZ06
Kracka's mods may help you;
​​​​​​https://www.corvetteforum.com/forums...port-cats.html
​​​​​​https://www.corvetteforum.com/forums...post1604776422
Old Oct 26, 2022 | 03:58 PM
BlaznZ06's Avatar
BlaznZ06
The reason I would ask the OP why is because of different applications for the needed HP.
I don't want turbo lag if I am drag racing, Yeah it may not be much, but tenths matter.
Now, if I just want bragging rights and street cred with how much HP my car has then I would consider turbo charging.
Old Oct 26, 2022 | 04:15 PM
The Rooster96's Avatar
The Rooster96
I just installed a paragon cat back exhaust... according to their dyno it's good for a 14hp increase. combine exhaust with an attack blue filter and you could MAYBE gain 20hp.. 30-50 is not happening. Definitely shaves some weight from the tail of the car as the stock npp weighs around 75lbs.
Sounds faster.. which makes it feel faster but 14hp isn't going to kick you in the ***.. but I suspect that the added hp combined with the maybe 45-50lb weight saving should give it some sort of marginal advantage over stock. That said.. short of forced induction the gains will always be minor on a car like the c8 because gm did a good job out of the box with intake and exhaust, tune etc. 495hp is respectable.
I did exhaust for the sound and to get rid of the god awful square tips.
I guess I can say I've got 500hp now tho...
To Extra HP
Old Oct 26, 2022 | 08:11 PM
dohabandit's Avatar
dohabandit
Why? Because more better!
Old Oct 26, 2022 | 08:18 PM
Hillslam's Avatar
Hillslam
2020 C8 of the Year Finalist - Unmodified
This forum...
OP asks for power mods and the first response is "Why U Want That?" - queue full page debate on why would you want more powah.
Geesh. I bet if he asked for the best adult diapers he'd get a better response.
Old Oct 26, 2022 | 08:51 PM
Maxie2U's Avatar
Maxie2U
Because people are allowed to ask questions. How that is beyond you is what’s mind boggling.
