Sponsored by: Wheel Design
Soler Throttle Controller
Old Nov 28, 2022 | 06:02 PM
faninc's Avatar
faninc
Banned Scam/Spammer
Default Soler Throttle Controller
Hi, anyone buy and install Soler Performance Throttle Controller? Any feedback appreciated.
I know what they are designed to do and not do having had a Vitesse in my C7. So purists don’t need to explain the no HP increase or butt the Dyno affect. The fact is it really wakes up the pedal and the feel of the engines acceleration curve, if you have never tried one no need to chime in.😇
thanks in advance
Old Nov 28, 2022 | 06:30 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Big fan of the Soler Throttle Controller. Mike from Soler recommended the Soler Throttle Controller set at SP.5 when I initially ordered from him a ported LT5/ZR1 95mm Throttle Body that matches up with a ported Intake Manifold.
Didn't expect to be overwhelmed with the TC but
the C8 feels entirely different, quick to respond to even the slightest pedal pressure especially in corners and exiting. The aggressiveness of the C8 is awakened.
SP.5 keeps the DCT RPM's higher for an extended period, too high and too long for me after a throttle up. Reduced the setting to SP.2 that drops the RPM sooner and is perfect for me.
The other day for the heck of it set the unit back to OEM. I can tell you the factory C8 acceleration setting has a lot of lag. Out of the 37 TC sensitivity settings I prefer #20 that is SP.2. Can't imagine setting this device in the 30's which is named Ludicrous for good reason.
Great mod and wouldn't go without it plus not a whole lot of cost for this item.
Old Nov 28, 2022 | 06:54 PM
faninc's Avatar
faninc
Banned Scam/Spammer
Default I added one to Camaro SS
Thanks for details! I added the Vitesse TC to my Camaro SS and used the language you used. “Woke up”the car beyond anything I expected! Also said was best $150 mod you can do!!!! Enjoy and hope to install soon after delivery but with cold weather likely will be next Spring.
Old Nov 28, 2022 | 08:07 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Google Soler on MECF. There's a detailed review and a lot of comments from people who have bought one. I'm very happy with mine.
Old Nov 28, 2022 | 09:04 PM
faninc's Avatar
faninc
Banned Scam/Spammer
Default Red Mist…
Thanks, what setting do you use on your C8 ? Have throttle body too or just the throttle controller?
Old Nov 28, 2022 | 09:46 PM
BlaznZ06's Avatar
BlaznZ06
Isn’t changing the throttle body on the C8 a real “b”?
More than what the effects are worth?
Old Nov 28, 2022 | 09:50 PM
faninc's Avatar
faninc
Banned Scam/Spammer
Default Bet Throttle Controller is more noticeable
I am betting Throttle Controller alone will provide a more night and day feel than throttle body alone…
Old Nov 28, 2022 | 10:13 PM
Red Mist Rulz
Only the controller, not the throttle body. Changing that out on the HTC is more work than I'm willing to do right now. And I"m happy with the car as it is now. Might be better with both, but the controller has given me what I want.
I've settled on Sport 5 (on a scale of 0 - 9). Anything higher than that and it gets a little touchy trying to get smooth starts in daily driving. Higher numbers might be OK in certain situations, where starting from rest isn't an issue, but too high and it becomes very difficult to modulate the throttle. Even on a track you don't want a hair trigger response.
I did try Sport 9 once, just for grins. It'll bring grins and giggles, but it's way t0o abrupt to be practical except in straight line acceleration.
(If my wife is going to be in the car, I'll knock it down to Sport 3, to make sure things are nice and smooth. Even at 3 it's noticeably more responsive than the OEM.)
Old Nov 28, 2022 | 10:17 PM
chevyvette1's Avatar
chevyvette1
I used to be like "those guys" until I tried a Vittesse Throttle Controller. Absolutely love them now. Currently have the Soler Version in the C7 Stingray 7 Speed... I even used them on both my C7 Z06s... one was an auto and one a 7 speed.
Old Nov 28, 2022 | 10:21 PM
faninc's Avatar
faninc
Banned Scam/Spammer
Default Chevyvette
What do you like better on Vitesse? I had one on my Camaro SS. Figured I try Soler on my C8 as they seem to get positive feedback. I also have not received response to emails to Vitesse over last three weeks. Thanks
Old Nov 28, 2022 | 10:54 PM
GoobTrooper's Avatar
GoobTrooper
Does this device actually reduce the input latency?
From their site it appears to map voltage from some throttle input to a higher voltage, so the ECM opens the TB more than it normally would. Leads me to think it wouldn't affect the latency, but I could be misunderstanding things.
Old Nov 28, 2022 | 11:08 PM
faninc's Avatar
faninc
Banned Scam/Spammer
Default Not sure of technicals
It vastly increases the throttle/ pedal response and provides the feeling the engine has really been unleashed! It is the best mod for the money having had one in my Camaro SS.
Old Nov 28, 2022 | 11:32 PM
chevyvette1
They both install the same, but I like the Soler better. I haven’t looked in a while, but if I’m not mistaken it’s even less money..
Old Nov 29, 2022 | 09:12 AM
I have the Bluetooth version of the Soler Throttle Controller on my C7 and it works great. Much better throttle response from the car.
Old Nov 29, 2022 | 09:52 AM
The Rooster96's Avatar
The Rooster96
How do these work in conjunction with the different drive modes? I usually drive my c8 in track unless im on the highway.
Old Nov 29, 2022 | 10:05 AM
SoCalJD's Avatar
SoCalJD
I just bought the Soler Performance controller. My 2023 C8 is my 1st Vette and after reading through this post I figured for $160 with cyber Monday discount, why not get this mod? Thanks all for the advice
Old Nov 29, 2022 | 10:29 AM
MikeinAZ's Avatar
MikeinAZ
it just makes the throttle response quicker, so each mode will feel more responsive, even track.
To Soler Throttle Controller
Old Nov 29, 2022 | 10:40 AM
bhvrdr's Avatar
bhvrdr
Its actually very easy. Took me 30 minutes first time.
Old Nov 29, 2022 | 10:52 AM
chevyvette1
Hi Mike, hey if you're ever in Tucson or if I'm up by you I would be happy to let you see how it works on the C7... I'm sending you a PM with my contact info... Ooops my bad... I thought you haven't used one...I see you have ​​​​​​​​​​​​​​
Old Nov 30, 2022 | 09:56 PM
vetted2damax's Avatar
vetted2damax
1st Gear
I didn't like the looks of the soler, but have heard of it quite a bit. Looks too much like the Chinese windbooster to me, rebranded. I tried the Maxx Boost for my '12 Camaro, three easy modes, no bluetooth, no confusion, worked great for me. https://www.sawyertuning.com/product...oller-booster/
Then again basic and simple operation is king to me, I don't need extra bells and whistles. The maxx boost cost me around $100 with some coupons i used if I recall correctly.
