I noticed something interesting the other day....I am near sighted but need nothing close up...I have to wear my glasses when driving. As its getting cold hear my top is up and i use the rear view camera...Its always been a little blurry but when I took off my glasses it was crystal clear What the heck......Maybe get a bio focal with clear glass in lower portion....any ideas????
bifocal, or progressive - with the lower portion a "plano" will work. I need significant correction, so my lenses would be somewhat thick. So, instead, I use a bifocal contact in my left eye, and a strong reading contact in my right eye. I can function that way with no corrective lenses. But for perfect vision in both eyes, I then can wear progressive lenses over the contacts - that provides full dynamic range of vision in both eyes. The advantage is that with the contacts, the lenses in the glasses are much thinner - and that also reduces the distortion that some experience with progressive lenses.
If you have the 2LT or 3LT the rear view mirror is a monitor, so situated and focuses a couple feet from your eyes.. It does not focus at infinity, like a reflective mirror. You can cycle between the two to see the difference.
Recall my distance vision in one eye got better when I was ~75! Apparently happens for some!
I have been wearing progressive lens for 35 years, mostly for reading and the computer. Only had my license require glasses from about that same time. I would remove my glasses for a few hours before going to the DMV and taking their eye test. Then thought heck I never take the off as they are also translons and in sunny NE SC most of the year need the sun glasses anyway.
I have perfectly clear view of the TV Mirror by setting it tilted as If I were trying to look at myself. Cleared it up for me as others report as well.
Keep using it with your glasses. Your brain will eventually adapt and it will be the best mirror you've ever used. TIP: as mentioned by Jerry U, set it to actual mirror mode, adjust it until you are looking into your own eyes, then switch to camera mode for best results. In my driving position this equates to adjusting it all the way down and to the left.
Guys, you are giving him answers to a question he never asked. He has no problem seeing things close up. His vision problem is seeing things far away, and this is what he wears glasses for. That is why when he takes his glasses off he can now see the rear view camera fine - as it is as if he is reading a book. In fact, I would venture to say that he has to remove his classes to read. That being said, I do appreciate the information about CLR technology.
So to the OP's question, yes, having bifocals with a clear lens in the bifocal area might work. The other option is to take off your glasses when looking at the camera mirror, which I don't think you want to do. Or, just live with a slightly fuzzy image as you only really need to know what is behind/beside you and you don't need to be able to read their license plate.
Thanks guys good info...getting old is such fun...In my youth my friends talked about who we could ask out and have some fun with and now its what hurts...what meds you are on...and what operation you need...But hey....still hear
Neither Lasik nor Clear Lens Implant will solve the issue. Both of those generally attempt to correct your eyes for distance vision. The problem is that the rear-view mirror is not at distance. You are effectively watching a TV picture about 2-2 1/2 feet away, so your focus is closer than infinity. Either just use progressive lenses and tip your head back a bit or do monovision contact lenses with one eye focused for near and the other focused for distance.
I thought I had it figured it out...Just get clear glass on lower sections..Called eye dr. and said they only have clear for upper part????
So I guess i will just have to lift up the glasses.....oh well..
Wrong- you can get a bifocal or progressive with an add or segment that would approximate "clear glass" but that would depend on your distance prescription. You will need to tip WAY up, though, to see the camera through the "reading" part
lasik doesn't solve this- the problem is presbyopia or aging of the lens in the eye not one of simple nearsighted or farsightedness- this is a concept that starts to become evident in your mid forties- before that most haven't a clue.
Clear lens extraction with a Extended depth or mutifocal implant can certainly fix it, albiet though, with the risk of intraocular surgery. A monofocal implant wouldn't work and monovision (one eye distance one eye near) isnt exactly for everyone. Face it getting old has its drawbacks - still better than the other option of not getting old
At 75 I got cataract surgery. That fixed things. 20/20 near vision and 20/15 far vision.
