Sponsored by: Wheel Design
Car shut down?
Old Jan 18, 2023 | 07:12 PM
Hockeyfun1's Avatar
Hockeyfun1
Default Car shut down?
I have my 2022 C8 plugged into a tender in my garage. I double clicked the remote start to start the car and it started for about 10 seconds then shut off. Any idea why or is that normal?
Edit: just got an OnStar notification through email:
An issue with the emissions system in your 2022 Chevrolet Corvette has been detected. Please service your vehicle within 7 days.
Old Jan 18, 2023 | 07:55 PM
NAVY_LDO's Avatar
NAVY_LDO
2023 C8 of the Year Finalist - Modified
Doesn’t the frunk have to be closed?
Old Jan 18, 2023 | 08:03 PM
Hockeyfun1's Avatar
Hockeyfun1
It is. The wire is routed in the top passenger side where there's an opening.
Old Jan 18, 2023 | 08:22 PM
Zormecteon's Avatar
Zormecteon
I was under the impression that a car should never be started with a battery tender connected. ..... . No surprise then that it shut itself off. ....
I don't know enough to say whether you were lucky that that's all that happened. ..
Old Jan 18, 2023 | 08:28 PM
StanNH's Avatar
StanNH
The manufacturers say it is safe to start a car with the tender attached. It should not cause any problems. I've done it with my CTEK's many times.
Old Jan 18, 2023 | 08:29 PM
blackvetterzo6's Avatar
blackvetterzo6
I’ve started cars with battery tenders attached hundreds of times, no problem
Old Jan 18, 2023 | 09:05 PM
Hockeyfun1's Avatar
Hockeyfun1
I just sat in it with the battery tender unplugged and started it up and it stayed running but I have a check engine light.
If I call the dealer, will they be able to remotely read the code? It's probably only been two weeks since I have started the car, and it's been on the tender the entire time.
Old Jan 18, 2023 | 10:10 PM
dohabandit's Avatar
dohabandit
If you remote start your car, it should run longer than 10 seconds. It won't run forever though, and the owner manual cautions about having the vehicle sitting running at idle for too long with no motion.
If you open the TRUNK, it will shut off immediately. I can only guess this is to prevent people from getting injured by the running engine, but really the serpentine belt area is pretty hard to reach!
If you open the FRUNK it will keep running.
I usually remote start and let my car warm up at least past 120-130F oil temp before I drive off. Maybe not needed with a dry sump, but it's an old habit and I just prefer the engine to have had a chance to get lubricated from top to bottom before taking off and putting stress on it.
Starting a car with a tender attached is not likely to be ANY risk to the car. The tender should have current limiting built in and an inline fuse (10A probably) to limit the current going through the tender/charger. Keep in mind, you are talking about a battery that is producing ~730CCA!
10 amps (even if your tender could do that) is a tiny drop in the bucket.
Old Jan 18, 2023 | 10:14 PM
Hockeyfun1's Avatar
Hockeyfun1
Also to note, I have a Borla ATAK installed at the dealer and the car gave me 100 plus trouble free miles with it. Not sure if this is just coincidence or what.
Old Jan 18, 2023 | 10:17 PM
Mark9's Avatar
Mark9
Conditions in Which Remote Start Will Not Work The remote start will not operate if any of the following occur: . The ignition is in any mode other than off. . A remote key is in the vehicle. . The hatch/trunk is not closed. . The convertible top is not fully open or closed. . The tonneau cover is not closed. . The hazard warning flashers are on. . There is an emission control system malfunction. . The engine coolant temperature is too high. . The oil pressure is low. . The 30 minutes of engine run time have been used. . The vehicle is not in P (Park).
Owners manual.....
Old Jan 18, 2023 | 10:18 PM
Kracka's Avatar
Kracka
Push the blue OnStar button, they'll be able to tell you what the code is for. I'm guessing it's your exhaust valves needing a relearn procedure since you just had the exhaust installed.
Old Jan 18, 2023 | 10:24 PM
If you have a check engine light on, the car should not start with the remote start. I know the 2015 Impala that I had was that way.
Old Jan 18, 2023 | 10:31 PM
Hockeyfun1's Avatar
Hockeyfun1
They did the relearn when it was installed. It worked fine for the 100 or so miles that I drove it before putting it away for the winter.
Old Jan 19, 2023 | 01:22 AM
Zormecteon's Avatar
Zormecteon
OK... thanks for the information. I stand corrected.
Old Jan 19, 2023 | 07:05 AM
449er's Avatar
449er
CF Community Team
Take the car to the dealer & use your warranty as it was designed to do
Old Jan 19, 2023 | 09:05 AM
Warp Ten's Avatar
Warp Ten
Did you try to restart ?
Old Jan 19, 2023 | 09:32 AM
Hockeyfun1's Avatar
Hockeyfun1
Yes, still CEL.
To Car shut down?
Old Jan 19, 2023 | 10:04 AM
VetteND's Avatar
VetteND
I'm surprised it started with a check engine light. My experience has been GM vehicles will NOT START with a CHECK ENGINE light. I've seen this many times. The car will have stored the code.
Old Jan 19, 2023 | 10:13 AM
LT2/3LT's Avatar
LT2/3LT
Unmodified C8 of the Year 2021 Winner
Remote start/run on my C8 automatically shuts itself off around the 15-minute mark. Yet to put a timer to it, but if I did...probably 15 minutes.
I unplug my trickle charger from the wall outlet when I do run it, just to be on the safe side. Glad to learn it may not be an issue after all, yet easy to unplug and plug back in when done.
Old Jan 19, 2023 | 11:28 AM
Warp Ten's Avatar
Warp Ten
If it were me I would take the car for a 30min drive. Shut down in your garage... wait 30mins and restart. Bet the CEL will not be on.
