Sponsored by: Wheel Design
Amazon engine bay lights mod
Old Jan 25, 2023 | 04:22 PM
galaxy_jason's Avatar
galaxy_jason
Default Amazon engine bay lights mod
These little lights are awsome for lighing the bay but
A) the batteries run down in a couple months even if not used.
B) they are hard to change whithout dropping them in the bay.
So I took the batteries out, direct soldered wires to the contacts and installed a 3x AA battery pack with switch.
Even though the pack is 4.5 volts they are brigher than with the 2x 3 volt coin batteries. And I can turn it off completely when not in use.
I mounted the lights with super sticky double sided tape and a bead of adhesive. Sanded down the back flat for better grip. Made it though the Texas summer no issues.
Old Jan 25, 2023 | 04:41 PM
Amoreloba's Avatar
Amoreloba
I had those for a little while before the heat eventually got to them in one way or another. They either stopped working correctly (not responding to the remote or erratically changing color / brightness) or were hanging on for dear life to the lid eventually. It’s a nice solution for $15 but for the future I’m just going to pony up the extra money to hard wire and epoxy something into the engine compartment. I kinda miss the cheap solution though.
Old Jan 25, 2023 | 04:49 PM
2024VETT's Avatar
2024VETT
Would it be possible to install them on the underside of the trunk cover to better protect them from the engine heat?
2024VETT
Old Jan 25, 2023 | 05:00 PM
galaxy_jason
I don't think its the heat. That's exactly what happens when the batteries get low. You can turn them on but then they don't respond to the remote. And the batteries that come with them don't last long. Even if you don't use them they are "listening" for the remote so they draw power. This solution should fix that.
Old Jan 25, 2023 | 05:18 PM
Maxie2U's Avatar
Maxie2U
I was going to add LED lights to the engine bay but realized I really don’t drive that much at night.
Old Jan 25, 2023 | 05:45 PM
combatninja's Avatar
combatninja
Even GM decided this was stupid.
Old Jan 25, 2023 | 07:50 PM
galaxy_jason
ummm, OK. Glad you like it.
Old Jan 25, 2023 | 11:04 PM
Nice job if looking to do an engine bay lighting on a budget.
Old Jan 26, 2023 | 08:03 AM
SoCal C8's Avatar
SoCal C8
Livin the Life
2024 C8 of the Year Winner - Modified
I did two versions….
Old Jan 26, 2023 | 04:57 PM
Zymurgy's Avatar
Zymurgy
Moderator
No. Their supplier of the carbon fiber trim that was part of the package went out of business. So, they dropped the option.
ZZ3 Engine Appearance Package, includes Carbon Fiber trim and lighting
Old Jan 26, 2023 | 05:16 PM
combatninja
And have been unable to find another vendor in 3 years?
Old Jan 26, 2023 | 05:37 PM
Zymurgy's Avatar
Zymurgy
Moderator
The package was not removed from the order guide until 8/1/2022:
Effective 8/1/2022, the following changes will be made to the Vehicle Order Guide:
  • Stingray Exterior section-(ZZ3) Engine Appearance Package, updated footnote 1 to now read "No longer available to order."
  • Z06 Exterior section-(ZZ3) Engine Appearance Package, add a footnote 1 to 1YH07 1LZ, 2LZ and 3LZ that reads "No longer available to order."
Old Jan 27, 2023 | 04:36 AM
prinzSD455's Avatar
prinzSD455
Finalist 2020 C4 of the Year - Unmodified
thanks for the heads up. I did not know this.
Old Jan 27, 2023 | 04:54 AM
Tim0shel's Avatar
Tim0shel
Lol I realized the same thing, actually have never drove mine at night that I can think of but I guess very early AM would count since ti was still a little dark out.
Old Jan 27, 2023 | 07:37 AM
449er's Avatar
449er
CF Community Team
Now you can go over to Ebay & get some Z51 stickers
Old May 2, 2023 | 09:09 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
These look great
To Amazon engine bay lights mod
