Sponsored by: Wheel Design
Saved by the Grill Protector
Old Feb 4, 2023 | 11:18 AM
Red Mist Rulz's Avatar
Red Mist Rulz
Originally Posted by 16falcon
I don’t think the side inlet guards are necessary, although I do have grill guards all the way across the front condensers. There is already a factory grill/protective screen in front of the fans deep in the inlets. The inlets should be inspected for debris occasionally, I have pulled one candy bar wrapper out of the side inlet. When I am forced to drive over paper or plastic bags I do try to check my rear view mirror to see that they appear behind me, if not, I check the front and the side inlets at my next stop. Usually they are clean, but it’s worth checking.
If you have a Z51, the 3rd heat exchanger is on the passenger side in front of the fan and grill. That said, the only thing I've ever found in my side vents was a leaf. One.
Old Feb 4, 2023 | 11:20 AM
Red Mist Rulz
Originally Posted by See8
Wonder if Checy will make grill guards standard on the 2024s? There is an OBVIOUS and CLEAR NEED for these, despite what engineers have stated.
The 2024 E-Ray CTF cars GM has been showing don't have them, so probably not.
Old Feb 4, 2023 | 02:12 PM
Fast Dawg's Avatar
Fast Dawg
Are they offering the Scrape Armor guards as an option? If not, it may be possible. They did it for Borla with their exhaust.
Old Feb 5, 2023 | 10:06 AM
STINGmole's Avatar
STINGmole
How many cars have overheated due to damaged condensers?
There's no NEED, other than cosmetic, and once you drive the car away, GM and the Engineers don't care about cosmetic damage.
That being said, I put guards on mine because they look better and reduce damage.
Yes, it's an option now.
Old Feb 5, 2023 | 05:01 PM
tadda's Avatar
tadda
Veteran: Marine Corps
Just installed grills today...Only 500 miles and there already was a few dings on the exchangers!
Old Feb 6, 2023 | 07:18 PM
Skidnik's Avatar
Skidnik
Cruising
Where did you source yours?
Old Feb 6, 2023 | 07:24 PM
tadda's Avatar
tadda
Customcargrills 4pc Mesh Set for Corvette C8 Customcargrills 4pc Mesh Set for Corvette C8
Old Feb 6, 2023 | 11:02 PM
buickrob's Avatar
buickrob
Originally Posted by LIE2ME
I had mine installed by the dealer during PDI....
Same, no regrets! I was going to get the Scrape Armor ones anyway so $125 or so to have them on from the minute the car got here was totally worth it to me.
Old Feb 7, 2023 | 10:54 AM
NB68's Avatar
NB68
Originally Posted by astepup
I too have an AY car with the grill guards but I never thought to paint them. Do you have any more pics showing the whole front end?
Sorry, been side-tracked dealing with a broken icemaker waterline which flooded the house for 3 days while I was away.
Front - end pics.
I purchased these off e-Bay + spray can of AY from the dealer for $15. I wanted to make the OEM hex grills stand out more.
They are the screw-in\double sided tape versions, so no T-ties. Paragon knock-offs I guess?
Old Feb 7, 2023 | 11:58 AM
Performance nut's Avatar
Performance nut
Personally, I think you would have smashed several fins on the condenser but I doubt it would have cracked/broken a cooling coil. You would have lost a very insignificant amount of cooling capacity and maybe been able to straighten the smashed fins with a comb (doubtful but never know). Aluminum is delicate but we aren't talking rice paper delicate. So long as you aren't eating a daily breakfast of rocks like that, I'd be more worried about your paint than the condenser.
Old Feb 7, 2023 | 12:20 PM
BlindSpot's Avatar
BlindSpot
Location has a lot to do with it too. Here in Arizona, there is so much construction going on everywhere, the streets and highways are loaded with dump trucks, cement trucks, and gardeners pulling trailers full of debris that are flying out of their trailers all the time....like a war zone. Broken windshields are almost a given no matter how careful you are.
Old Feb 7, 2023 | 12:29 PM
tadda's Avatar
tadda
AMEN!
I try avoid driving on the 10 as much as possible...
Old Feb 8, 2023 | 03:54 PM
  #33
NB68's Avatar
NB68
Not sure what Museum Delivery charges to install them but these are now an option on the 2023 builder for $495! IMO they look almost the same shape \ quality as mine which were $80 for the set on eBay + about an hour for a relatively simple self- install.
Old Feb 9, 2023 | 07:38 AM
  #34
/Bear/'s Avatar
/Bear/
2025 C8 Z06/7/E-Ray of the Year Winner - Unmodified
2021 C8 of the Year Finalist - Unmodified
I don't have side inlet guards on my C8, and I haven't found them to be necessary either. I assume the same will be true on an E-Ray because hopefully they have the same protective screens as a C8. However, it appears that there's no such protection on a Z06.
Old Feb 9, 2023 | 11:31 AM
  #35
NB68's Avatar
NB68
That's the same with a standard C8 w Z51 as it also has an exposed radiator in there.
Old Feb 9, 2023 | 09:22 PM
  #36
16falcon's Avatar
16falcon
St. Jude Donor '21
Yup, the picture I posted of my side inlet is a non Z51. If I had a radiator in there like the Z51 or Z06 I might consider the side inlet screens. The fact that I have only had 1 small piece of paper in there in 12,000 miles still makes me wonder, even with radiators, would screens be necessary? Lots of you have the Z51 package, is anyone seeing damage to the cooling fins on the radiator in the passenger side inlet?
Old Feb 10, 2023 | 12:35 AM
  #37
mgfoursixeight's Avatar
mgfoursixeight
I installed mine during the PDI and when I got home (15 miles) there was already a rock stuck in one of the grills the size of a small marble. It confirmed that the grills were money well spent.
To Saved by the Grill Protector
Old Feb 10, 2023 | 08:23 AM
  #38
Warp Ten's Avatar
Warp Ten
Did you have to straighten out the Hex and touch up the paint on the Hex from the impact?
Old Feb 10, 2023 | 09:24 AM
  #39
mgfoursixeight
They are powder coated, so the finish remained intact. There is a very slight bend in the hex. However it's in the corner and not noticeable at all, so I left it as is.
Old Feb 10, 2023 | 09:34 AM
  #40
RKCRLR's Avatar
RKCRLR
My Z51 has front screens but no side inlet screens. I do not have any damage on my side radiator but I only have 8K miles on my car. I pick out a leaf every once in a while but I'd have to do that if I had a screen also.
I don't think there is a need for side inlet screen unless you want the asthetics.
