Sponsored by: Wheel Design
front trunk problem
Old Feb 2, 2023 | 03:40 PM
jgzo6's Avatar
jgzo6
Default front trunk problem
Just had my new c8 delivered from Mac Milkin to las vegas. Since i got car about 10 days ago i have a problem getting front trunk to close I have contacted dealer who basically told me to close harder. That did not work My accidently I found if I press the front button under the headlite two times while trunk is open it will close. Dealer has never heard of this problem but is checking . Note car was built in Nov 22. Wondering if some new change. Anyone have same issue or knowledge please chime in. Thanks
Popular Reply
Feb 2, 2023, 07:57 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Originally Posted by HRDTOPC54FUN
In case you aren't aware, typically, closing the Frunk is a two-part process.
Push straight down leaning forward with the palms of both hands (preferably with a soft cloth to protect the paint) and then let go. That engages the safety latch.
Go back and repeat the process and push down a second time and that should engage the primary latch and fully close and lock the frunk.
Never had to do that on mine. Just push down with one hand in the center, above the latch, until it's completely closed. Sounds like maybe your latch needs adjusting, too.
Old Feb 2, 2023 | 04:53 PM
golfer-racer's Avatar
golfer-racer
1st Gear
My car was built the 2nd week in Dec. and I had the same problem, but I couldn't close the front trunk. Had to drive the car in emergency mod, not over 45 mph, to the dealer. They adjusted the latch and now it closes, but you have to push really hard to get it closed.
Old Feb 2, 2023 | 04:55 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
Old Feb 2, 2023 | 05:38 PM
jgzo6's Avatar
jgzo6
Dealer had me try that. Also had me try latching both at same time No go.
Old Feb 2, 2023 | 07:57 PM
Red Mist Rulz
Old Mar 5, 2023 | 11:45 AM
gt490's Avatar
gt490
Sounds like a sticky latch.
Old Mar 5, 2023 | 10:03 PM
Avanti's Avatar
Avanti
I'm sorry, but all this sounds simply... silly. How long have we been adequately making and closing car "lids" of all sorts?
Old Mar 5, 2023 | 10:40 PM
123sugey's Avatar
123sugey
Dig
it sounds silly until you try to close the frunk. It clicks down twice and still is not closed. There’s a plastic info sticker in the frunk just saying push down once then push down again, it’s f up. Thank God I tried it in my driveway… I would have been 100% embarrassed if I was at the airport in front of anyone … trying to close the crap.
The only way I can close it is pushing down pretty hard… hear a click. Let off .. push down again. And YUP … it is NOT closed !! I have to again push down once again and just maybe it catches on and is locked/shut.
Surely I’ll be going to the dealer to get this fixed.
So…. On a very positive note … the dual clutch trans in our C8 is the best trans ever in a Corvette. Stick cars aside as I love manual cars.
Old Mar 5, 2023 | 11:41 PM
johnodrake's Avatar
johnodrake
Moderator
Never had an issue with closing mine. Using my thumb and forefinger.
Old Mar 6, 2023 | 01:09 AM
4thC4at60's Avatar
4thC4at60
Push straight down leaning forward with the palms of both hands (preferably with a soft cloth to protect the paint) <snip>.
I'm guessing you don't drive yours in the rain....
Old Mar 6, 2023 | 07:55 AM
Ken_C8's Avatar
Ken_C8
St. Jude Donor '09, '21
2024 power closing frunk will be amazing. As others have said I lower mine and then press to the first click and then press harder to the second click.
Old Mar 6, 2023 | 08:00 AM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
I found if I press the front button under the headlight two times while trunk is open it will close.
Does this really work?
Old May 18, 2024 | 09:21 PM
c8ron2022's Avatar
c8ron2022
I took delivery of my 2024 ZO6 3 days ago and I have the same issue. I figured out the double. push in head light button and all it good. I thought the senor goes to sleep when the light goes out but and it does BUT
it actually won't close some times before the light quits. I think leaving lid open for more that. a couple min sensor won't see it. I push the head light switch and works Normal
this cant be. how it is to work. Anyone figure this out yet
Old May 18, 2024 | 09:22 PM
c8ron2022's Avatar
c8ron2022
yes it works and I have to do it when it won't work. but I just pushed heading button once and all is good
Old May 18, 2024 | 11:18 PM
c8ron2022's Avatar
c8ron2022
just found this in the manualIf the hood remains open for more than
10 minutes, the vehicle will enter sleep mode and the hood may not power latch. To exit sleep mode press the front fascia touchpad or the E on the remote key, or open any door and then push briefly on the outside of the top of the hood until the latch clicks into engagement, then let go of the hood. The hood will then close
Old May 19, 2024 | 12:10 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
You're right, of course, but the original post was in 2023 so that car did not have the soft close frunk. Different problem.
To front trunk problem
