Bought a new 2023 HTC a couple months ago, and because of the weather here - straight from the dealership to the garage at home.
Since then, it has not been driven at all, and I have done a bunch of cosmetic changes, and today swapped out the brake pads, to Powerstop units
While doing the brakes, i noticed that the syeering wheel was not locked.
After dropping it back onto the wheels, the steering wheel still moved freely. Moved the car back and forth out of the garage and back in, shut it down, got out and locked the car, but the wheel still moved freely.
Do these cars not lock the steering wheel when shut off? I thought it was a federally mandated anti- theft measure. What am I missing here, or doing wrong?
Wow, I haven't thought about steering column locks in my Corvettes for a number of years.
I think that my 2002 was the last of my Corvettes to have it.
I believe that after the rather troublesome "Steering Column Lock" issues with the C5, GM decided to eliminate the steering column locks.
I think some 2005 Corvettes - those with manual trannies - may have had a steering column lock. My 2008 automatic car did not.
My 2016 didn't have it, nor does my 2023.
Bill B.
Thanks for the reply Bill!
I do remember our 1998 roadster had the dreaded column lock issue about 1 week after we bought it(used). Bought the kit online with relay to defeat it.
Checked our 2020 Explorer, and 2020 CT5, and neither steering wheel lock either. My 2020 ZL1 is on our lift, but i suspect it's column doesn't kock either.
Doesn't have anything to do with whether the car is key start or not. It's a cost cutting thing. Plain and simple. It's not required here, so GM doesn't put it on, and they can save however many dollars per car by leaving it out.
It's just a solenoid and a bracket. This is what the solenoid looks like. There's a little metal stud that pops out to lock the column. It's used on a lot of GM cars. https://www.ebay.com/itm/304572941228
Steering column locks aren't required in the US but some type of vehicle immobiliation when the key isn't present is required. In the case of a C8 it is the inability to shift the car out of Park without a key (although this isn't reason you can't shift it out of Park without the engine running).
My 1969 Corvette with a clone L88 engine. On the freeway, the carburetor got stuck in near full open throttle. I was afraid to turn off the ignition for fear the steering wheel would lock. And I didn't want to push the clutch in. Finally, I as I was starting to enter earth escape velocity, I realized I could probably click the ignition back one notch into the accessory power position and kill the engine. Success. I got rid of the steering wheel lockout feature on that car and also my now 1970.
Federal regs require a steering wheel lock OR a transmission shifter lock. Since you can't get the C8 out of park without the key, that meets the requirements of the regulation.
Thanks, learn something every day. I still like my answer better since there is no electrical component to fail and either lock you in or out of steering. Not being able to put it in drive without the key is a good idea however.
That's been, at least, a C6 failure problem, My C6 got stuck in Park because of the electrical release solenoid failure. This is a huge problem for someone on an overnight trip, far away from home.
I'd be curious to see the actual wording of this. Because the way you're saying it, a manual C7 is illegal.
Don't think this a fed reg, considering the easy way new Kia's and Hyundai's are stolen with a screwdriver and a USB cable.
Approval) (Amendment) Regulations 1975). In the United States, concern in the mid-1960s about car theft was fueled by reports that so-called "joy-riders" were from 47 to 200 times more likely to be involved in a traffic accident than other drivers (Karmen, 1981). In 1966, Federal Motor Vehicle Safety Standard 114 was passed, although this was not to become effective until 1970. It required all manufacturers to equip new passenger cars with a key-locking system that prevented the car from being steered or driven forward without the ignition key. With the exception of SAAB, who focused on the prevention of forward motion, all of the major manufacturers selling cars in the US market began installing steering column locks in their vehicles in 1969 (Lee and Rikoski, 1984).
Maybe "smart keys" like the Corvette have count as "preventing forward motion"? But it doesn't seem like it would, since you can still push the car.
Theft Protection – for all vehicles Each vehicle must have a starting system which, whenever the key is removed from the starting system prevents: (a) The normal activation of the vehicle's engine or motor; and (b) Either steering, or forward self-mobility, of the vehicle, or both
I guess the loophole is the phrase "self mobility." At the time the reg was published, the only effective way to do that was to lock the transmission. Now, with the electronics, you can prevent the car from starting at all. In theory, but some Hyundai and Kia owners would question that.
I have a feeling those cars are in violation of the regs.
