Sponsored by: Wheel Design
Painting wheels
Old Apr 14, 2023 | 09:44 AM
Dave Kitch's Avatar
Dave Kitch
Default Painting wheels
I want to change the color of the wheels from aluminum gray to black, Has anyone painted their wheels?
DMK
Popular Reply
Apr 14, 2023, 10:12 AM
combatninja's Avatar
combatninja
I wouldn't put a penny into doing anything with the stock wheels. They are ugly and have weak offsets. The several hundred bucks for dismounting/powdercoating/remounting & balancing would be better spent towards aftermarket wheels that you like. I bet you'd be into them for $600ish all said and done. Waste of money on stock wheels in my humble opinion.
Old Apr 14, 2023 | 09:59 AM
Kevin A Jones's Avatar
Kevin A Jones
All I can tell you is that I fairly often see wheels with paint popping off / peeling when stopped by vehicles at stoplights. If I ever wanted to change a wheel color I'd get them power coated unless the vehicle was a beater.
Old Apr 14, 2023 | 10:03 AM
67rstbkt's Avatar
67rstbkt
Plenty of people have without issue, however, it's well worth it to find a powdercoat shop and have that done instead.
Old Apr 14, 2023 | 10:10 AM
aboynamedsue's Avatar
aboynamedsue
I have had two sets of wheels powder-coated and have been very happy with the results. Obviously prices will vary, but mine were $500 for all four wheels each time (Saint Louis area).
Old Apr 14, 2023 | 10:12 AM
combatninja
Old Apr 14, 2023 | 10:58 AM
tsigwing's Avatar
tsigwing
Took my car to a shop. Dropped it off on Thursday morning. Picked it up Friday afternoon. Wheels powder coated for $600. Very happy with that.
Old Apr 14, 2023 | 11:32 AM
dohabandit's Avatar
dohabandit
I had mine powder coated for $600.
Old Apr 14, 2023 | 11:53 AM
C8OnOrder's Avatar
C8OnOrder
Making the stock wheels black at least helps hide the ugliness. For $600 thats steep though.
Old Apr 14, 2023 | 04:28 PM
Tonylmiller's Avatar
Tonylmiller
Don't laugh, but my wheels had significant damage on my C7 Z06. I used PlastiDip on them and they came out looking fantastic for a few dollars a can. If you don't like it, just peel it off.
Old Apr 14, 2023 | 04:39 PM
dohabandit's Avatar
dohabandit
$600 to strip, prep, and powder coat four wheels, PLUS mounting and balancing tires is steep?
Welcome to inflation!
Old Apr 14, 2023 | 07:37 PM
Innovated's Avatar
Innovated
$600 or more to powder coat , plus the cost to have them removed. Then the cost to have them all remounted , balanced and installed .
For another $600 to $800 you could have had a quality set of aftermarket wheels installed
Old Apr 14, 2023 | 07:44 PM
dohabandit's Avatar
dohabandit
$600 was inclusive of everything, plus they let me use their shop while the wheels were being worked to swap my brake pads, install grill screens, and to install paragon lowering collars and adjust the rear ride height. I did all the latter myself, but they let me work on my vehicle while it was on their lift. $600 was a deal if you ask me.
The aftermarket wheels I would purchase cost 3-4 times as much.
Old Apr 14, 2023 | 07:50 PM
Innovated's Avatar
Innovated
Yeah , honestly that's not too bad, especially if you don't mind the look of your stock wheels to begin with .
And you're right about good aftermarket wheels - every time I see a set of wheels i really like, they are always at least a thousand dollars per wheel
Old Apr 14, 2023 | 08:48 PM
MAD Matt's Avatar
MAD Matt
Most factory wheels on just about every brand are painted and not powder coated. I've painted many wheels and it's all in the prep work as to the outcome. A painted wheel, when properly prepped will hold up just as well as powder coating and can be easily touched up. If you have to touch up a powder coated wheel, what do you use.....paint! But I do agree, powder coating is the way to go if cost isn't an issue.
Old Apr 15, 2023 | 02:01 AM
Go the powdercoated route. Will last a lot longer.
Old Apr 15, 2023 | 06:29 AM
CanadianVetster's Avatar
CanadianVetster
Try the PlastiDip first. Only costs a few bucks.
see if you like it and how is lasts. If it chips or peels you can easily respray.
then Power coat for a permanent solution.
Old Apr 15, 2023 | 11:06 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I have a buddy who worked in the metals industry for years. He told me it is a falicy is that powdercoat is more durable,etc. He noted that if a painted surface is prepped and applied properly it is every bit as durable. Powdercoat is basically dried paint chips that melts under heat for an even, smooth finish. In the end he told me there is no real advantage either way. Be careful in that there has been problems noted powdercoating wheels where the wheels were overheated via the process. The wheels were ruined as the high heat compromised the integrity of the metal. Make sure you use a powdercoater that has experience with wheels and/or blended alloys. There are a lot of amateurs powdercoating these days.
Old Apr 15, 2023 | 11:11 AM
tsigwing's Avatar
tsigwing
I am not arguing, but...
Powder coating provides better performance than wet paint—it is more resistant to chipping, scratching, and other wear because of the thermal bonding it undergoes during curing, and because it can be applied in much thicker layers.
Maybe true, maybe not, but the consensus sure seems to agree.
Old Apr 15, 2023 | 11:29 AM
gliot1's Avatar
gliot1
Perception or what you heard? My buddy applied it all, did it all for 35 years for industrial applications. It is simply different process to achieve a similar end result. If the paint/powder was epoxy vs an oil paint would make diff. I have another friend who worked for Rust Oleum as a chemical engineer who concurs that no big advantage of powder, other than it achieves a typically smoother, even finish...durability not any big advantage. I did many sets of valve covers over the years out of a rattle can. I had buddies who insisted powdercoat. Theirs didn't outlast mine and didn't look any nicer. The paid a few hundred....I paid about $7. Would I rattle can my wheels? No, but I would take them to a trusted body man to booth paint for much more reasonable. In fact most stock car wheels are not powdercoated, but painted.
To Painting wheels
